Post by axekicker on Oct 13, 2010 0:57:41 GMT -5
I'm starting to spec my custom strat that will be an HSH configuration. I know the neck humbucker will be a Sustaniac so I'm not sure I can do anything to that pup. But I want to play with the bridge and middle single coil. Can I do series/parallel/phase/split with the bridge pickup? How many switches am I looking at (not interested in push/pull pots). I'm guessing two. One will be an on/on/on and the other is an on/on, yes? What can I do with the single coil? I'm also going to put in a Wolf solo switch and a pre-amp switch. Thanks!
Post by wolf on Oct 14, 2010 2:11:24 GMT -5
Well since you mentioned my name, I guess I'll answer this. How about this modification? www.1728.com/guitar2a.htmIn order for you to do that modification, you'll have to think of the pickups on your guitar as the 3 pickups on a Strat™ type guitar:  This requires 1 4PDT switch and four DPDT's. I was thinking of suggesting a Seymour Duncan Triple Shot for the humbucker but it would be very difficult, if not impossible to get that single coil in series (as well as parallel) with the humbucker. Oh and a Seymour Duncan Triple Shot costs 30 dollars.
Post by ashcatlt on Oct 15, 2010 18:10:03 GMT -5
Re: the title of the threads.
If we're talking just the two coils and some switches, you have exactly 6 possible configurations: One Coil, Other Coil, Both Series, Both Parallel, SOoP, and POoP.
Now, with the two coils as close together as they are found in a humbucker, both OoP options are going to be useless. Even when the coils are further apart these would be special effects type things. In an HB the signal will be so quiet and thin - and obscured by noise - that you'll never use them.
So we've got only 4 meaningful options. There are various ways to achieve them. It can be done with a single DP4T switch, or a couple DPDTs, or whatever.
Now, if you can afford a capacitor or two it opens up another possibility which is sometimes called Half-Parallel or Broadbucker. Basically you wire the two coils in series and put a cap across just one of them - let's call that one Coil A. Coil A has its highest frequencies shorted (like turning a Tone down to 0) but the high freqs from Coil B find it easier to go through the cap than through Coil A, and are therefore not rolled off the by the added inductance. You end up with a hybrid sound with the highs of an SC and the lows of an HB. The cap value here will depend on the specifics of the pickup and personal preference, but standard tone cap values are a good place to start your experiments.
Theoretically, I think, an inductor could go in place of the cap, but I've never heard of it being done, and don't know what it'll sound like.
There's also a similar thing where you can get Half Out of Phase, but I think that too would be less than exciting in the context of a close positioned pair of coils.
Post by axekicker on Oct 18, 2010 1:45:20 GMT -5
Thanks guys, I really appreciate it. The cap idea sounds very interesting. Are there schematics floating around that demonstrate this technique?
Post by axekicker on Oct 18, 2010 1:49:23 GMT -5
I've never run across a 4DPDT switch. Is it an on/on/on switch? Is that the middle part of the Wolf schematic, that 9-terminal switch?
Post by wolf on Oct 18, 2010 4:25:35 GMT -5
axekicker You mentioned a 4DPDT switch. If that is referring to my diagram it is actually a 4PDT switch and can be found on the Internet. (I think both digi-key and mouser sell it).
You mentioned a 9 terminal switch. I don't think I use anything like that. Can you be more specific?
