peterrabbit
My mileage DOES vary
Post by peterrabbit on Mar 7, 2011 13:26:48 GMT -5
Egad - once more into the breach: Perhaps this will do it? Peter
Post by sumgai on Mar 7, 2011 14:10:30 GMT -5
PR, OK, I'm gonna sign off on that one! ;D BTW, you do realize, don't you, that you've "doubled" the connection between the Neck pup's 'hot' wire and the Volume pot..... There's a red wire going directly to the pot (around the upper right corner of the drawing) and there's another one that goes first to the Blend control, then on to the ser/par switch, and then on to the Vol pot, same terminal (which is the correct one). Schematic-wise, it makes no difference, the connections are the same, but...... physical wiring-wise, it does make a difference only in that there's no point in wasting both wire and time to solder it up, eh? Like I said at the outset, I have confidence in you, that you could solve the issue - and you did! +1 for you. ;D sumgai
peterrabbit
Post by peterrabbit on Mar 7, 2011 22:35:39 GMT -5
Fantastic - but I certainly could not have done it in a trillion years without you guys - many, many thanks to you all.
I will be building this over the next little while - I'll try to remember to take pics and record the resulting sounds of this foray. Anybody know of a good sound-file hosting site - like Photobucket, but for MP3s?
Peter
Post by cynical1 on Mar 8, 2011 8:53:02 GMT -5
Anybody know of a good sound-file hosting site - like Photobucket, but for MP3s? The best two I can recommend would be these: SoundClickSoundCloudSoundClick is only .mp3's for free. SoundCloud doesn't care. HTC1
peterrabbit
Post by peterrabbit on Mar 8, 2011 12:53:56 GMT -5
Thanks Cynical1!
Peter
