Post by sumgai on Mar 14, 2006 2:50:29 GMT -5
servant,
Where does the 'hidden' end of that 4.7Kohm resistor connect to?
servant
Post by servant on Mar 14, 2006 17:23:21 GMT -5
Where does the 'hidden' end of that 4.7Kohm resistor connect to? In series with C2, the yellow cap. I guess I should have put a blob of solder on the drawing.
Post by ChrisK on Mar 14, 2006 17:51:11 GMT -5
Yep,
Essentially, there is a two-pole response from this circuit (as in poles and zeros and not "lugs" QED).
If the circuit is analyzed for the 0.018uF cap (what it effectively is in series w/ a 0.1uF) and 4K7 Ohm resistor when set to "0", one can see that it's just like a standard tone control, with the resistor limiting the "zero" resistance of the pot to 4K7, and hence reducing the peaking effect that I mentioned earlier in this thread.
The 0.1uF cap on the wiper does complicate the response somewhat (pSpice need apply for a clear view) in that it forms a variable parallel RC network (the 0.1uF cap and the top half of the pot) in series w/ the series network comprised of the rest of the pot, the 0.022uF cap, and the 4K7 Ohm resistor.
While the "Grease Bucket" circuit may indeed catch all of these "greased electrons" causing such aforementioned (by Fender at least) undesirable "tone stuff", I've found it somewhat effective to just not turn the tone control all the way to "0".
But then, marketing is (and the "Highways" have been quiet(ly ignored) lately).
Post by sumgai on Mar 14, 2006 18:03:35 GMT -5
Chris, Sounds like that was a case of job security for certain Fender engineers, wouldn't you say? ;D Don't turn it down as far, indeed. I can just see it now: "But these things go all the way down to ZERO!" to you! sumgai
Post by UnklMickey on Mar 14, 2006 18:05:54 GMT -5
...Essentially, there is a two-pole response from this circuit (as in poles and zeros and not "lugs" QED).... spoken like a true engineer! but Chris, even as inspiring as your technical expertise, and the puns you slip in are, i must say that one post by Wolf has kept folks even more captivated. unk
Post by ChrisK on Mar 15, 2006 20:13:36 GMT -5
Even an old fart (well past breeding years) quoting Oscar Wilde, won't help those "still in the herd".
"The pleasure is fleeting,
The position ridiculous, and
The expense darnnable." (SuBtle fontification afoot!)
But, few males would do much of anything if'n it wasn't directly fun-full.
Post by sumgai on Jun 27, 2006 13:38:44 GMT -5
....... i must say that one post by Wolf has kept folks even more captivated.
unk Just remember, no matter how good she looks..... somewhere, right now, some guy is tired of putting up with her crap! Do you really want to inherit his problems?! sumgai
Post by ChrisK on Jun 27, 2006 14:36:17 GMT -5
All "hobbies" are high maintenance!
Post by Mini-Strat_Maine on Jun 27, 2006 15:00:09 GMT -5
All "hobbies" are high maintenance! "There is a very fine line between 'hobby' and 'mental illness.'" -- Dave Barry, “Fourteen Things That It Took Me Over Fifty Years To Learn” (Twenty-five things, if you get it from this site: www2.gol.com/users/coynerhm/25_things_i_have_learned.htm.) ;D
Post by Mike Richardson on Jun 28, 2006 20:06:57 GMT -5
It's a low-cut filter into a high-cut filter. The resistor keeps it from "bottoming out" as you roll the knob back. Interesting, but hardly revolutionary. It was probably created by Bill Lawrence.
Post by UnklMickey on Jun 29, 2006 16:52:29 GMT -5
...Interesting, but hardly revolutionary. .... and the question is: what is the definition of Fender today? for answer, see above. lol sorry guys, i just had to.
kurik
Post by kurik on Jun 9, 2013 14:06:04 GMT -5
Ok, so I'm looking at that Varitone circuit and thinking it could go in a rack. Perhaps if one was using a Garcia-type effects loop from/to the guitar before the master volume. Would the cable run wash out any usefulness of the external tone box? Just posing a question as I don't have the aforementioned effects loop, but curiosity will have its way.
Post by ozboomer on Jun 16, 2013 5:56:38 GMT -5
While the "Grease Bucket" circuit may indeed catch all of these "greased electrons" causing such aforementioned (by Fender at least) undesirable "tone stuff", I've found it somewhat effective to just not turn the tone control all the way to "0". So, with all the discussion around the "Greasebucket" modified tone control, has anyone found it actually does produce any significantly different sound compared to a standard (treble cut) tone control that's only turned-down part way?? Is it worth the (minor) effort to make the modification??
Post by JohnH on Jun 16, 2013 6:17:59 GMT -5
While the "Grease Bucket" circuit may indeed catch all of these "greased electrons" causing such aforementioned (by Fender at least) undesirable "tone stuff", I've found it somewhat effective to just not turn the tone control all the way to "0". So, with all the discussion around the "Greasebucket" modified tone control, has anyone found it actually does produce any significantly different sound compared to a standard (treble cut) tone control that's only turned-down part way?? Is it worth the (minor) effort to make the modification?? Meanwhile 7 years later.. I had 'grease bucket' circuits on the tone pots of my American Special Strat. I couldn't notice anything different from a normal pot which only goes down to 1. J
Post by sumgai on Jun 16, 2013 12:29:41 GMT -5
kurik does get the Grand Prize for ressurecting the dead! Very nearly seven years since the last post, which beats the old record (held by chuck) by more than 22 months. Way to go, kurik! sumgai
Post by b4nj0 on Jun 16, 2013 16:58:22 GMT -5
I held the yellow jersey for resurrection back in 2007, but 7+ years sure is a doozie...It would be easy to trounce, but not very sporting n'est ce pas?
Post by ozboomer on Jun 17, 2013 1:18:03 GMT -5
I held the yellow jersey for resurrection back in 2007, but 7+ years sure is a doozie...It would be easy to trounce, but not very sporting n'est ce pas? Sure... but some places (not so much with our comfy, Nutzy home) will get themselves tied-up in knots if you post a new item covering a topic when there's already an extensive (albeit ancient) thread discussing the same topic... Here, I like to think, we don't mind either way... (!)
Post by sumgai on Jun 17, 2013 2:34:03 GMT -5
Since the only thing you'd get for sacking the quarterback (i.e. resurrecting the oldest thread since we started) is a gen-u-wine NoPrize, I guess it'd be fair dinkum....
Post by b4nj0 on Jun 17, 2013 4:21:53 GMT -5
So, not way to go then, back to greasebucket tone trickery...
Post by ux4484 on Jun 17, 2013 10:29:32 GMT -5
But you see here... These controls go to ZERO...
(Inverse Spinal Tap)
Post by sumgai on Jun 18, 2013 2:27:48 GMT -5
Is that where the drummer suddenly appears out of thin air, landing right on the stool, all in one piece, and looking like he just came out of a fight with a wildcat in a phonebooth? How often is that expected to happen, because ST lost a lot of drummers due to bizarre cirumstances, ya know.....
