flyingpig
Post by flyingpig on Feb 26, 2015 5:24:01 GMT -5
Ok this is the link of the original Double Barrel wiring from John Atchley This is the link on this forum, that without the help of "newey" and "JohnH" (THANKS) would never happen And here are the Layout and dimensions on how to fit the Super Switch on to Fender Strat (mine is eric claptons blackie i dont know if has different routing of any other strat, but i dont think so) About the mod, This mod is for Fender Stratocaster with three single coils and it adds a 5 way super switch along with the standard 5 way switch. The super switch is used to provide four very useful new pickup combinations. In the remaining position the super switch passes the signals on to the standard five way switch that gives all of the standard Stratocaster-style combinations. Working from the bridge towards the neck the new switch gives the following combinations: 1. Pass through to standard switch. 2. Neck and bridge in parallel. 3. Middle and bridge in series. 4. Neck and bridge in series. 5. Neck and bridge in series and out of phase.
flyingpig
Post by flyingpig on Feb 26, 2015 5:24:53 GMT -5
Post by sumgai on Feb 26, 2015 13:22:28 GMT -5
Mr. Pig, Good job! Now, my only request, and it is just that, not a Command From On High.... Your postings don't list what we call a Truth Table. This is sorta like a chart that clearly and quickly shows what switches yield which pickups in combination. Reading through verbiage (text) is fine for getting the details, but the casual reader would like to know, right away, what the circuit can do. A chart (or as we Nutz call it, a Truth Table) answers such questions without any muss or fuss. Please, can you modify your above post(s) to include such a thing? TIA. Oh, and to the NutzHouse! You are now officially Nutz to the n th degree! sumgai
flyingpig
Post by flyingpig on Feb 28, 2015 5:56:39 GMT -5
Mr. Pig, Good job! Now, my only request, and it is just that, not a Command From On High.... Your postings don't list what we call a Truth Table. This is sorta like a chart that clearly and quickly shows what switches yield which pickups in combination. Reading through verbiage (text) is fine for getting the details, but the casual reader would like to know, right away, what the circuit can do. A chart (or as we Nutz call it, a Truth Table) answers such questions without any muss or fuss. Please, can you modify your above post(s) to include such a thing? TIA. Oh, and to the NutzHouse! You are now officially Nutz to the n th degree! sumgai Hello sumgai I have modified the post to be more Nutz If i can do something more let me know Thanks
Post by sumgai on Feb 28, 2015 13:32:51 GMT -5
fp, That works like it says on the tin - thanks! sumgai
