Post by wolf on Apr 6, 2015 18:06:39 GMT -5
Hello Folks, I was wondering about switching the Grease Bucket Tone Circuit in and out of the tone path. What I wanted to do was switch it so that when it was switched out, the "standard tone circuit would become active (tone pot with .02 mf capacitor and nothing else.) Have I succeeded?
Post by ashcatlt on Apr 6, 2015 18:14:36 GMT -5
Looks like it woke to me. When the switch connects to the bottom lugs, it's just like Grease Bucket thing, and the other direction the extra components are shorted and it is a standard tone control.
Post by wolf on Apr 6, 2015 18:56:26 GMT -5
Thanks for the quick reply ashcatlt. Seems I only have 9 more posts to go before I hit "1,000".
Post by JohnH on Apr 6, 2015 19:28:37 GMT -5
yep! Try to do your next 9 posts within 17 days. There's a really good reason! J
Post by wolf on Apr 7, 2015 1:49:30 GMT -5
Okay John, I think I'll be able to make 8 more posts in 17 days.
Post by pablogilberto on Jun 13, 2020 18:09:50 GMT -5
Hello!
Upon checking your Greasebucket Circuit, I notice that the Tone Control connects to the middle lug (output) of the Volume pot.
I also saw some diagram online where it is connected to the left lug (input) of the Volume pot?
What is the original wiring and what is their advantage disadvantage?
Thank you!
Post by JohnH on Jun 13, 2020 19:45:16 GMT -5
I think Wolfs drawing is not the usual way. If would normally connect to the outer volume pot lug.
Seriously, I has a GB tone control on my Strat. The only reason for it I could see is if you like your treble control to stop just before minimum, while there is still a bit of treble and before a mid honk sound develops. It makes is easier to find tbis tone since its then at the end of the travel.But it doesn't really do any tones that a normal tone can't do.
