dantheguitarman
working on a guitar, what else is new
Post by dantheguitarman on May 23, 2017 21:10:59 GMT -5
hello all, so i am converting a squier body to harness my long time project.
i am currently using an after market 5-way switch long story short i need help with the wiring of the switch.
1 volume, 2 tones, two humbuckers and one hot rail pickup.
this is what i am looking for:
1- neck 2- neck and bridge 3- mid 4- mid and bridge 5- bridge
or
1- neck 2- neck and mid 3- mid 4- neck and bridge 5- bridge
hopefully someone can provide me so help and guidance, as i am getting itchy to assemble and play
Post by sumgai on May 23, 2017 23:59:09 GMT -5
dan,
How quick and cheap do you want this? You can accomplish your desired combinations if you're willing to re-order the listed positions. Check this out:
1 B 2 B + N 3 N 4 N + M 5 M
What I did was simply swap the Neck and Mid pickups. Of course, swapping the Bridge and Mid also works, you still get the important combo of B + N, but in the opposing position (2 vs 4, or 4 vs 2, depending on where you start numbering).
If that doesn't work for you, then we'll need to remove the standard Strat/Tele switch (it has only four (4) terminals on each side of the wafer) and insert a souped-up switch designed for this kind of work. In most guitar-modder circles, we call this a 'half-Superswitch', but you might find other websites that call it something else, I dunno.
The deal is, with this half-Superswitch, there is a unique terminal for each switch position. (A total of six (6) on each side of the wafer.) That lets you hook things up so that you can have your original desired order of combinations. Costs more, and takes more time to install, but no one can tell you what you have to do, only what you might want to consider. ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Let us know how you want to roll.
dantheguitarman
Post by dantheguitarman on May 24, 2017 21:03:33 GMT -5
the attached image is the switch i am usingAttachments:![](//storage.proboards.com/1212256/thumbnailer/klTfkvefmbkwZiuXUsdt.png)
Post by newey on May 24, 2017 21:34:25 GMT -5
dan g-man-
First of all, I am remiss in not welcoming you promptly. . .
Hello and Welcome to G-Nutz2!
The switch you show is a regular import-style Strat 5-way switch. With that switch, you are limited to what sumgai suggested- swapping the positions of the neck and middle pickups. This is easy enough,and is easily reversible if you ever decide to sell the guitar. You may find that you have to lengthen the middle pickup's wires a bit, depending upon how much slack you have to work with.
But if you insist on the N + B in position 2 or 4, then you're looking at a new switch as sg said.
