diont
Post by diont on Feb 7, 2018 10:57:59 GMT -5
Hello I've got a new humbucker with a white red wire a black wire and a green silver wire. I want to make a hsh set-up with a single coil with a white and black wire. And a humbucker different type with a red and a white wire. This can be connected to a volume pod, 2 tone pods and a 5 way switch. Does anyone have a wiring scheme for this?
Post by newey on Feb 7, 2018 17:30:00 GMT -5
doint-
Hello and Welcome to G-Nutz2!
Since wire colors vary from one pickup manufacturer to another, simply listing the various colors you have doesn't really tell us much. If you know the manufacturer(s) of these 3 pickups, we can work out the colors from published data. If you don't know the manufacturer of one or more of these, some testing will be necessary. Testing will require a multimeter.
As far as a wiring diagram, we'll be happy to help, and there are a number of HSH schemes around here. But the more basic question is: What combinations of pickup coils do you want? I could just randomly post a number of diagrams for HSH schemes, but that seems a rather unfocused way to go about this. Do you just want what would essentially be regular SSS Strat wiring, just substituting the HBs for the single coils? Or would you want to split one or both of the HBS?
Also, the type of 5-way switch matters as well. A standard Strat-type 5-way will present you with very limited options, while a Superswitch or other types would expand your choices.
