Post by JohnH on Feb 27, 2021 5:31:22 GMT -5
I don't think you can go series to parallel with one pole , and not moving the 5 way. But you could use two of the 5-way positions to do it. Then that single'pole switch could do other things like coil cut or switching a pickup on.
syddd
Mar 24, 2021 6:44:42 GMT -5
Post by syddd on Mar 24, 2021 6:44:42 GMT -5
To clarify, are you changing the humbuckers from two coils in series to two coils in parallel? Or are you wanting to change your 'Middle' position from parallel to series?
