Post by UnklMickey on May 11, 2006 21:35:18 GMT -5
hey Bluebeetle, i did a little more research for you on that switch: here's how Gibson is using it on the Ace Frehley LP: so it can get you -- A , A + B , C -- for your choices. don't know if that is anything you want, but thought you might like to know. unk
Post by ChrisK on May 29, 2006 21:22:05 GMT -5
SP3T mini toggle switches are really very similar to DPDT in that they have 6 terminals (2X3).
They switch like this:
1<--2---3 4<--5---6
1<--2---3 4---5-->6
1---2-->3 4---5-->6
If 6 is wired to 2, you get SP3T
5->4 5->6->1 5->6->3
They usually have silver cadmium contacts and normally should have about a 100mA wetting current, but they usually work OK in guitars (although not guaranteed w/ such low level/current signals). I prefer the gold flashed contacts, but they're much harder to find (I have to go the OEM route). Or, Heh, Heh, Heh, free samples.....
I think that the SP3T mini toggle can be had with the 3/8 bushing also.
If you want a variety (more than 3) of combos, the rotary is the way to go. If you want to fool with the mini toggle, one CAN get a DP3T (12 terminals).
