Spotting a fake Seymour Duncan Humbucker
Sept 10, 2022 15:28:22 GMT -5
b4nj0 and baridoom9 like this
Post by frets on Sept 10, 2022 15:28:22 GMT -5
Hi Guysđ¸đ¸đ¸
I had the opportunity to pull a harness from a Les Paul that had fake Seymour Duncan Humbuckers. And I thought it would be good to explain the differences between a real SHN-4 and a fake SHN4 as I spot them. The differences are incredibly subtle and the Chinese fakes have become so good, that they are nearly indistinguishable. Others on the forum may have more insights, but this is how I spot them. I provide examples.
I have tried to do my best with the photos; but, it is hard to control the lighting in my shop.
Some believe that the easiest way to spot a good fake is the lettering of âSeymour Duncan,â. You can see a difference between the two Iâve depicted. But the fatter logo for the real one is a later font by Seymour. Remember, they are both pad printing. So trying to spot by looking at the lettering is relevant but Seymour did change the size of their logo. Usually, the quality of the font is one of the keys with the fake logo not quite as sharp. Also, fakes have more of a serif to them (usually). This is not always the case though. But if you have a set with the smaller font that looks new, with a very serif font, you could be looking at a fake. You have to take this in account with other clues.
Letâs look at the baseplates. The baseplates are near identical. The quality of the etching is so similar that attempting to spot a fake is nearly impossible using this method. The color is identical. But, the corners of the baseplate give us a clue. A real Duncan has a slightly rounder corner on the edges than the fakes. This might not show up in the photo; but, look at the edge of the two and you can see a rounder cut to the real Seymour. If you are looking at a slightly âsquarerâ corner, you probably have a fake.
In addition, the oblong lead hole is rectangular in the real Seymour. If you have a roundish oblong hole, you most likely have a fake. This is a good clue and the rectangular edges in the real ones is visibly squarer.
One of the biggest clues is the number label. The number label on the fakes are always in a smaller font. Iâm not an expert on the size of fonts, all I know is if youâre looking at a really small font the likelihood is high that you have a fake. A font of say 3 is suspect.
In addition, my biggest clue on the serial number is the number â2â and the letter âSâ. The 2 on the fake always has more of a serif where the right bottom of the 2 having a slight tail. I show this in an illustration with another real Seymour.
The S is also different where the fake has more of tail serif on the end of the S than do the real Seymourâs.
The weight of the font does not distinguish a real from a fake. Seymour has used light fonts and dark fonts.
A big clue to sighting a fake is the actual sheen to the label for the serial number. The sheen on fakes always has a slight âsilverishâ hue. You have to hold it in the light to see this upon reflection. Real Duncanâs always have a satin or flat sheen. Itâs not a lot of difference between a fake and a real; but, if you have a little bit of a sheen that appears silverish when the pickup is examined under the light, you probably have a fake.
The actual number on the fakes can be different. So know that fakes often have differing number/lettering coding.
The pole pieces and the actual âthicknessâ of the pickup give no insights as they are the same.
The sheen and thickness of the plastic are identical. But the holes at the end of each bobbin are smaller by about a 1/2 mm on a fake. Real Seymourâs have large bobbin holes.
Next, on the fakes, the lead is fatter. And the individual pickup wires are fatter. I really only know a few gauges. So I canât tell you the gauge difference. Sorry. Just know a Seymour has a slimmer lead wire. Iâd say by about 1mm. So if it looks a little skinny, itâs most likely real.
There probably are more differences that folks in the forum will know. Just be aware that the difference to a fake and a real is so minimal that it is really difficult to spot a good fake from the real deal.
The boxes they come in are identical and I have wondered if the actual Seymour boxes are made in China. I canât tell by the box.
Iâm just sharing visual details that I have noticed.
But, if you measure a fake vs. real bridge model (usually the JB), youâll find that the fake bridge always comes in in the 14k-15k region. The real deal is going to be 16k+. Unfortunately, on the neck pickups, there is not much of a difference in resistance.
If you happen to get a fake in the box (new) you will receive Phillipâs head mounting screws and regular gauge sprints, with real Seymourâs that are new, you usually get a fatter spring and a flathead mounting screw. The spring is really fat. However, if you find a Seymour used, the seller might have sold it with regular Phillipâs head mounting screws. But do look at the screws as the flathead slotted screws are usually what you see with Duncanâs.
What about sound differences? Yes, I can hear a difference between a fake and a real. But those not familiar with working with pickups would probably not recognize the differences. A fake has a thinner treble heavier sound. But again, this difference is audible only if you are accustomed to the Seymour sound.
To sum up, buying from reputable dealers is the best way to avoid fakes. But if youâre buying a used Seymour Humbucker on EBay or Reverb, these points may help. The differences between real and a good fake are slight but perceptible if you know where to look. You will be surprised by how good a good fake looks.
In the future, Iâll detail the differences in single coils. As I think of more differences, I will edit this post. Iâm that way, people searching on the internet will be able to find this post. Currently, there is not much out there about the differences. And someone could easily end up with a fake when buying used.
