Post by frets on Sept 30, 2022 12:45:28 GMT -5
Happy Friday Guys😸😸😸 I hope all of us are safe from the Hurricane. As you all may know, I’ve been on a Bass Cut and Treble Cut Wiring expedition. This one uses a Bourns Dual Gang Push Pull to accomplish the Bass and Treble Cuts. The Dual Gang Push-Pull has been discussed on the Forum before and can be found on EBay for about $12 shipped. This mod avoids the need for concentric knobs (as found in my previous diagram post). The cuts work interactively. You can pull up and push down and rotate to arrive at the tone you want. This is a powerful tone harness for a Tele. It gives the guy a Bass and a Treble. I have the cuts set to the nF values derived from the G&L Legacy. You could deepen the bass cut to 33nF if you so desired a little more depth on the treble cut. The 4-Way gives you the extra position of Series.
