Post by ssstonelover on Jan 20, 2024 0:54:09 GMT -5
In conjunction with the though process that led me to this diagram tele tapped pups 4-way switch + DPDTs also inspired by the Duncan diagram tappped Tele 5-way switch I thought about the option of using an Oak Grigsby 6-way switch, another under-utilized switch that is out there. This would allow me to tap both the Neck and Bridge pickups. In this execution the idea was one single switch do do all the switching, with the limit being 6 combinations, the limit of the switch itself. Certainly the used of 'helper' switches would up the combination, but no more than with the other diagram I made up (the 4-way with the DPDTs mentioned above which as a bonus also has a series connection). I have not built this but it seems straightforward enough. If I made any mistake do let me know if see something I missed
