Post by chrisdurham on Apr 9, 2024 16:01:16 GMT -5
Hello.
I am trying to upgrade a First Act ME-537 guitar. The body only takes one pickup, a humbucker. I have a Seymour Duncan 4 wire humbucker. I also have two Mojotone 500k CTS DPDT push/pull potentiometers. For the past couple days I have been scouring the Internet trying to find a wiring diagram for a possible configuration of these electronics. I have not been successful.
I would greatly appreciate it if you folks could email me a few wiring diagrams indicating possible scenarios for this setup. Any configuration I would be interested in must include an option for coil split. I am also interested in the possibilities of series/parallel toggling, as well as phase switching.
Any help you could offer me would be greatly appreciated.
Thank you, Chris Durham
Post by reTrEaD on Apr 9, 2024 19:09:50 GMT -5
Hello chrisdurham . Welcome to GN2. I removed the email address from your post for two reasons. - To protect your privacy and the likelihood of your inbox being spammed.
- We prefer to engage in conversation in the public space so others can participate, knowing what's already been covered. An so onlookers can also benefit.
Here is a drawing I modified from Guitar-Electronics that should suit your needs. The DPDT aren't show as being mounted on the pots, so you can assign them however they suit you. When pulled, the DPDT on the right over-rides the DPDT on the left and single-coil mode is selected. North (slug) coil only. When it is pushed, the pickup is in two-coil mode. The left DPDT selects series (pushed) or parallel (pulled) Wait for another guitarnut to proofread my work to insure I haven't made any errors.
Post by newey on Apr 9, 2024 19:48:09 GMT -5
reTrEaD, chrisdurham- RT's diagram checks out by me, with the proviso that the white wire connects to common lugs on both switches. Where the zigzag was drawn over the series/parallel switch, it threw me at first as to whether a connection was intended there- it is.
Post by chrisdurham on Apr 9, 2024 20:09:02 GMT -5
Thank you both so very much!
Post by chrisdurham on Apr 9, 2024 20:11:24 GMT -5
By the way, what does the orange symbol on the tone pot represent?
Post by reTrEaD on Apr 9, 2024 21:19:42 GMT -5
Post by chrisdurham on Apr 9, 2024 22:06:08 GMT -5
Thank you again.
