monradon
Post by monradon on Mar 18, 2007 21:42:41 GMT -5
Someone from here is telling my buddy that the pot bodies either vol or tone should not be grounded because it causes a ground loop On gibson style pickups I been grounding the pots for years ?
Post by ranchtooth on Mar 19, 2007 8:43:42 GMT -5
I think that as long as you have only one path to ground, (ie the ground lug on your output jack) you will not have any ground loops at all. I like to have every single ground coming together directly in a single point, such as the back of the volume pot. Then from there, straight to the output ground. No loops!
monradon
Post by monradon on Mar 19, 2007 10:51:22 GMT -5
Yes me too
Post by ranchtooth on Mar 19, 2007 12:58:50 GMT -5
If its not broke, don't fix it.
or.. if its not broke, its not complicated enough yet.
