gunther
Post by gunther on Apr 1, 2007 22:02:01 GMT -5
Hi all, I'm a big fan of this site, have read heaps! Now i wish to change the wiring on my stratocaster. It is currently wired with normal 5 way switching, master vol/tone, and a neck on switch Basically i have little use for the 2/3/4 positions on it, and the extra 2 positions dont sound too interesting either. What i wish to do is replace the 5 way switch with a 3 way which selects neck/both/bridge. From there, the signal goes to the master vol/tone......now heres the tricky bit: Then it goes to a switch which puts the middle pickup in series with whatever else is selected. I think this wiring will work really well live, putting the middle pickup in series should be like having an onboard boost of sorts. I can work out most of the wiring, i just need help with the 'middle pickup in series' switch. I wish to use an on/on dpdt switch to do this, if possible. Thanks alot if you can help me out or provide opinions Edit: one extra question - If it implement this wiring scheme, and my master volume is turned all the way down, and my middle pickup switch is on....will the middle pickup be on by itself? Thanks!!!
Post by ChrisK on Apr 1, 2007 22:53:26 GMT -5
Do you specifically want the middle pickup in series with the output of the volume pot for a reason, or do you just want the middle pickup series driving what the three-way switch has selected?
A SPDT switch can be used to put the middle in series with what the three-way switch has selected.
If a DPDT ON-ON-ON switch is used (a three position toggle switch), it can select between;
a. what the three-way switch has selected in series with the middle, b. what the three-way switch has selected, or c. what the three-way switch has selected in parallel with the middle.
OR
a. what the three-way switch has selected in series with the middle, b. what the three-way switch has selected, or c. the middle only.
depending on how it's wired.
gunther
Post by gunther on Apr 1, 2007 22:56:37 GMT -5
I definately dont want to use an on/on/on switch. Its too complicated for live use.
Is there any difference with putting the middle pickup before or after the volume pot???
I just thought it would be handy to put the middle pickup after the volume pot IF i could use it on its own when the master volume is turned down. Also to use the switch as a killswitch (when i've turned the volume down from the 3-way output).
Post by UnklMickey on Apr 2, 2007 11:15:53 GMT -5
hi Gunther,
i think i see what you are going for here.
putting the middle-series after the volume, will do 2 interesting things.
1 - with the volume at zero, toggling the switch will give you the stutter effect, going from middle only to silent.
2 - adjusting the volume will reduce the amount of contribution from what is selected on the 3-way. a blender of sorts.
since you will be using a 3 way to select the other 2 pickups, the 'hole' that would have occurred in position 3 of the 5-way will not be a problem.
the one thing that will not be possible, is to use the middle at reduced volume. as long as that is acceptable, you will probably be happy with this.
gunther
Post by gunther on Apr 2, 2007 15:34:10 GMT -5
Yep i totally understand this! I'm pretty sure this is what i want....but i'll never know until i wire it up.
A diagram would be much appreciated. Thanks
gunther
Post by gunther on Apr 2, 2007 18:02:53 GMT -5
dgeekoo
Post by dgeekoo on Apr 5, 2007 3:14:35 GMT -5
This is a mod that I made on a Strato with a reverse-wound reverse polarity middle pick-up. I made the first "tone-pot" a "dial-in-pot", and the 2nd tone a "master-tone" pot. With the dial-pot at minimum ("0" position) it is a standard strato. With the dial-pot at max ("10") we have mid&neck in serie in position 5, mid only in positions 4-3-2, bridge&mid in serie in position 1. With the dial-pot in itermediate positions we dial progressively the bridge/neck pups in paralel for 2/4 positions, or serie in 1/5 positions. Schematic is here: forums.rgc.ro/index.php?act=attach&type=post&id=19971
