Post by Ripper on Feb 3, 2006 11:40:40 GMT -5
I never tweak my guitar necks. Jobs like that make me nervous so again, I leave it to the pros. My 70's Strat has the micro tilt neck. What happens if I put the little adjuster wrench in there? Does it move the neck up and down slightly?
Post by RandomHero on Feb 3, 2006 15:08:43 GMT -5
The micro tilt on fender necks is made to adjust the angle at which the neck leaves the body. It's a common procedure to "shim" necks; put picks or cards or other little bits in the neck pocket to compensate for bow or alter action. The micro tilt just provides a cleaner, built-in method of doing that.
Post by lunaalta on Feb 3, 2006 16:31:00 GMT -5
On mine (73 strat) it allows sideways movement! So if the guitar gets the slightest stress, sideways, the thing moved out of line:+( I have it shimmed up so it won't move. I also have it screwed out, so no adjustment made, and things are just right. I must say, I'm a happy bunny as far as it's sound is concerned....(especially as it is now hum and buzzless, thanks to GuitarNuts) :+)
Post by mlrpa on Feb 26, 2006 21:31:13 GMT -5
When using ANY of microtilt, remember to loosen the screws on the neck a touch. "Cause if you don't, you strip them, or the micro tilt screw.
