Post by Mini-Strat_Maine on Mar 11, 2006 23:36:08 GMT -5
if i do this mini, will it void my warranty at all? Because i know i do have one. Oh, yeah, I didn't mean you should necessarily try that, unless you really didn't want to take it to the shop for some reason. Especially if it's still under warranty, having a pro look at something is always the best bet. Like U.M. said, it could be some oddball thing that we haven't mentioned yet. Things like that sometimes turn out to need an expert's touch. And if it's a Tusq nut, that's a Graph-Tech product, so that would kinda drop the nut from the suspect list.
Post by jdl on Mar 12, 2006 0:25:48 GMT -5
ok, I tried unk's tip at the bottom of his post. The noise was more noticeable on the first and third frets, it was slightly noticeable on the fourth, and a bit worse on the second. I think i need to get some sleep and listen to it with a "fresh pair of ears".
thanks guys; james
Post by Runewalker on Mar 12, 2006 13:35:30 GMT -5
mirpa's capo test is more definative and if that it the test you performed then it sounds like fret issues, unless as Unk suggests something more ontoward, or even the string issue mirpa mentions.
However, like most have suggested if it is under warrenty then by all means make the company stand behind it. Get a pro to fix it for free.
Good Luck. I will continue however, to search for some guitar pro raga files. You could start with Within you Without you, Beatles.
RW
Post by jdl on Mar 12, 2006 16:03:53 GMT -5
thanks for all the help guys, i'll keep you posted as i try to resolve the problem. And yes, i will be accepting any raga tabs for at least a few weeks.
james
Post by jdl on Mar 13, 2006 17:21:16 GMT -5
wow do i feel dumb!!!! I took my guitar in to a local guy, and i guess their was a slight hump in the neck. Sorry for all the trouble i caused y'all thanks for all the help guys james
Post by UnklMickey on Mar 13, 2006 17:27:38 GMT -5
no worries James.
Post by mlrpa on Mar 13, 2006 23:41:21 GMT -5
No problems. I enjoy puzzles of this nature!
Post by jdl on Mar 14, 2006 0:42:45 GMT -5
i'm just kicking myself, i mean it was so obvious. I could have had my guitar fixed a week ago!!!!!
james
