Post by fobits on Apr 27, 2006 20:36:00 GMT -5
I've just finished (or mostly finished) fitting a plug in the tremolo hole of my Beringer, in order to mount a solid bridge. For anyone who is interested, I can explain exactly how it's done. 1) Use a half-round file and a rat-tail file to remove the lip around the opening. Try to make the sides straight and parallel to each other, just rounded a bit at the corners. The Beringer is made of something resembling balsa wood, so this part goes quickly 2) Search out the best and most exotic tonewood in your collection of plywood scraps. Glue pieces together to obtain a thickness of 1 1/4". Cut a rectangular piece a little bit bigger than the hole. 3) Spend about three and a half hours fitting them to each other. Sand a little on the plug and try it. File a little bit on the guitar and try again. Continue until you get a tight press fit. 4) Spread a layer of Elmer's carpenter's glue on the plug and inside the hole, and let it soak in for 5 minutes. Spread another layer and wait another 5 minutes. (Balsa wood absorbs a lot of glue). Spread a third and final layer and try to insert the plug into the hole. 5) Realize too late that the water-based glue, as it soaks into the wood, will cause it to expand. 6) Push the plug in as far as it will go. Then lay another piece of wood on top and BLAM, BLAM, BLAM on it as hard as you can with a hammer, attempting to drive the plug down level with the face of the guitar. 7) Snatch up the guitar and dash to the kitchen sink. Use wet paper towels and your thumbnail to remove the half-hardened glue which is smeared all over the front, before it gets so hard that it can't be budged. 8) Contemplate the fun you're going to have sanding down the plug, which still protrudes a bit above the face, without wreaking the paint. That isn't the whole project, but it's enough to get you off to a good start. ;D Happy luthering!
Post by Runewalker on Apr 27, 2006 21:06:49 GMT -5
...5) Realize too late that the water-based glue, as it soaks into the wood, will cause it to expand.
Happy luthering! A beautiful and touching tale. I laughed, I cried, I went "oh, yeah, I have a few stories from the school of "hlll, if he can do it, any idiot can do it." The idiot
Post by RandomHero on Apr 28, 2006 1:42:28 GMT -5
Hehe. I did the same thing with a deck of cards, a scrap of one of the balconies in the apartment complex where I live, and some Dunlop Stubby 1.5 mm picks. And my trusty framing hammer.
Post by sumgai on Apr 29, 2006 14:20:40 GMT -5
RH, Ah, but did you use the correct size of framing hammer? You do know that this operation requires that you swing a 32oz. unit, otherwise you'll lose all that concentrated force!
The picks, however, were just right! Good call on your part! ;D
Post by sumgai on Apr 29, 2006 14:25:22 GMT -5
Frank,
It's made of Bass wood, a close cousin of balsa. All of your points apply, except that you didn't need to use so much glue, in so many applications (layers). It's times like this when parallel sides can act against you. Next time, try for a bit of a slant, making things look more like a wedge. If the sides are strictly parallel, then all that's holding the block in place is the glue, and with string forces pulling on it over time, that's not a good idea.
Post by fobits on Apr 29, 2006 20:20:37 GMT -5
Yes, I can see the logic of that, but it was hard enough getting the sides (more or less) straight with my primitive tools. Forget about filing an angle of 3.5 degrees in the body and 3.25 degrees on the plug. As for next time, let's just say that I'm not in a hurry
vroom
Post by vroom on Apr 29, 2006 20:47:14 GMT -5
I, too, used primitive tools. A handsaw and my own personal sanding block-- the driveway. When I realized I had grinded just a little too much off,some popsicle sticks got wedged into the gap. MacGyver winced.
Post by Runewalker on Apr 29, 2006 22:57:23 GMT -5
Post by fobits on Apr 30, 2006 11:14:01 GMT -5
Thanks, Runewalker, for the link. There's a ton of good stuff there. Who knows, I might even find the courage to adjust the thruss rod and neck. I've been afraid to touch those things, for fear that I would be writing a post about how to stick a neck back on with rubber bands and chewing gum
