wesman
Post by wesman on May 13, 2006 14:58:40 GMT -5
Just bought a new Gibbo jackplate for my project; however the radius is a bit larger than the side of the body.
I’ve bent import jackplates before with no problem, Using a tuna can & brute force, But this brass one refuses to yield.
Any ideas on how to do this with simple hand-tools?
Thanks in advance, Wesman
Post by RandomHero on May 13, 2006 15:50:11 GMT -5
Try applying heat, and don't be afraid to break out a couple pairs of pliers. (Pad the grips with t-shirts or rags, and bend slowly and carefully...)
vjmodman
Post by vjmodman on May 25, 2006 21:23:17 GMT -5
Sandwich the jack plate between two peices of hard none fkexiable material (like some scrap wood or two peices of plexiglass) and put a clamp on the two peices of wood and squeez it together until it bends into the shape you wan't.
I wouldn't try heat unless you really really need it. It could discolor the plate if you apply too much heat.
Post by ChrisK on May 25, 2006 22:19:33 GMT -5
Find a steel pipe of the proper inside diameter. Find an adjustable oil filter wrench, (or better yet, an adjustable chain pipe wrench), a thin aluminum "sacrificial" plate and wank away.
It's gonna take some wanking.
Or, if'n it ain't finished, sand the body down to the proper radius under the plate.
wesman
Post by wesman on May 27, 2006 9:24:27 GMT -5
Thanks for the replies,
What I ended up making was a concave wooden caul, lined it with leather (a piece of old belt), sandwiched the plate between that and and a little league bat, striking the bat with a rubber mallet in a rocking motion.
Gotta give it to Gibson, I aint seen a jackplate that tough in years.
Wesman
