Post by vonFrenchie on Jul 12, 2006 12:26:53 GMT -5
I know that 90% of strings snap at the bridge. (thats what I've heard) And I'm used to seeing it (the tune-o-matic bridge is notorious for this) but recently I've had alot of strings snap at the tuners. 9 times out of 10 my strings break way up at the tuners. Is the caused by my crappy d'addario strings or am I doing something wrong? Is it the extra amount of tension on the thicker strings?
I use D'Addario XL Strings .013-.056. Should I start using 10-46 instead of 13-56? Right now Im out of a high E so I'm begining to think that its the extra tension.
Post by dunkelfalke on Jul 12, 2006 14:55:34 GMT -5
try locking tuners. they are cruel to the strings in a different way. locking tuners are very practical anyway, will put them on all my guitars eventually.
Post by vonFrenchie on Jul 12, 2006 22:50:47 GMT -5
I'm not sure what type of tuner I need. I know tuners come with different hole sizes. How can I tell (without removing my tuners) what kind I need?
Post by dunkelfalke on Jul 13, 2006 0:31:15 GMT -5
you can't, really. the easiest way is to buy 10mm tuners and if the holes in your guitar are 8mm just mill them to 10mm.
Post by bam on Jul 13, 2006 11:28:00 GMT -5
sorry, late reply.
You can try sanding your tuner's hole with a 500-1000 grit sandpaper.
(the exact same fix for the string-breakage-at-the-bridge problem).
Post by vonFrenchie on Jul 13, 2006 23:05:17 GMT -5
Hmm... Well dunkelfalke.... because this isnt Germany... I think ill just go buy some gotoh's and if they dont work ill sand it to 13/32nds of an inch (the American measurement system sucks!)
Post by dunkelfalke on Jul 13, 2006 23:56:16 GMT -5
try planet waves trim locks. they aren't that expensive and they are very practical
