momo
Post by momo on Feb 16, 2007 22:25:04 GMT -5
Ya so I read up about metal plates behind the bridge pup, I did the Beast mod with the foil, will the metal plate interfere with the shielding? My bridge pup is the lowest of the 3(5.97 ohms) so I think the plate would help. Also I dont have to spend money on a prefab one, I have a 2 millimeter plate that has the perfect width and all I have to do is cut it in lenght. The thing is thought that I read you have to fix the plate to the pup in order to stop it from howling and screaching, so can I glue the plate to the bottom of the cavity? or do I absolutley need to fix it to the pup?
as usual, thanks for all the response ;D
