bigaldo
Post by bigaldo on May 27, 2007 14:28:53 GMT -5
Anybody know of a P90 type Humbucker sized 7 string pickup?
Post by crazymanandy on May 27, 2007 19:50:59 GMT -5
I'm not aware of anyone that makes 7-string Humbucker-sized P90's. You'd probably have to have it custom made (or make it yourself).
CMA
Post by sumgai on May 28, 2007 0:35:56 GMT -5
bigaldo, Well, lessee here........... we want a P-90 pickemup, that means that the poles are in the center......... an' we want it to buck the hum, which means two coils........ Hmmmm, if we combine #1 with #2, we get a stacked coil arrangement, not a side-by-side, which makes sense. And it has to be humbucker-sized..... no problem, the humbucker was originally designed to fit where the P-90 used to sit, before it was phased out. Now, all we need to do is tack on an extra pole-piece, and we're all set, right? Uh oh....... no can find tha tone. At least, not in the more-or-less standard ways. Looks like you may be asking a custom builder for a custom jobbie. Hope your wallet is feeling fine now, because when you're all done, it's gonna be singing a different tune. sumgai
bigaldo
Post by bigaldo on May 28, 2007 15:22:54 GMT -5
Thanx for the info guys.Son likes what I did to my Peavey Impact,Dimarzio H.B. bridge,GFS H.B. sized P90 in neck,3 way,with push/pull to split bridge H.B. to single coil.Alot of usefull sounds.He wants me to do it on his 7 string Schectur.I think I'll just try splitting the 2 stock H.B. pups and see if he likes it.
Post by sumgai on May 29, 2007 4:41:21 GMT -5
bigaldo Are you perchance referring to this thread? HTH sumgai
