Post by ux4484 on Feb 2, 2007 10:23:18 GMT -5
I haven't played for almost two weeks. I received a slice on my left ring finger across "the zone" when a paper cutter (roller type) blade fell off it's track. I'm just able to play today. I nursed it with anti-biotic salve and kept it covered until yesterday.....made the last week and a half feel like a year. It did take longer to heal, because I work with my hands. Does anyone have some better healing methodology they've had success with?
Post by sumgai on Feb 2, 2007 12:29:05 GMT -5
Superglue?
Post by gfxbss on Feb 2, 2007 13:39:26 GMT -5
you can also try the liquid ban-aid if your like me and allergic to super glue. also, try finger condoms....
Tyler
Post by ux4484 on Feb 3, 2007 13:16:31 GMT -5
Well....it was a pretty deep slice, probably could have used a stitch in hindsight, but it is O.K. to play with now. I've had enough Superglue on my hands over the years to ever think of putting it in a cut that deep.....though I suppose that a combo, liquid band-aid with a coating of SG over it might have done the trick...... ......hmmmm .....it maybe time to call the patent office
Post by sumgai on Feb 3, 2007 14:27:52 GMT -5
Dan, For some esoteric reason, cyanoacrylate is sterile - it has no agents that will react adversely with living organisms. Still, you don't want to insert it deeply into a wound, it might seal off blood vessels. I've seen where hospitals and doctors now use superglue to suture smaller wounds - they don't even do anything inside, they just pinch it tight, smear some goop on top, and tell you to re-apply as needed. (May be every few hours, if you're busy and exercise that body part often. At rest, it should last over-night.) sumgai
Post by ux4484 on Feb 3, 2007 15:30:39 GMT -5
Dan, Still, you don't want to insert it deeply into a wound, it might seal off blood vessels. sumgai Hence the wink.... heh....you know my real Name!!!! Next thing you know, you'll be telling me what my screen name stands for If you get the admin gig....your title should be "Clairvoyant Admin"
Post by sumgai on Feb 6, 2007 2:21:02 GMT -5
Dan, We'll see if anyone else here gets it, I'm sure I'm not the only one with a passing interest in that particular field! sumgai
Post by gfxbss on Feb 6, 2007 19:06:15 GMT -5
SG,
i get a blister wherever the stuff touches me. who knows what causes it, i just have it chaulked up to an allergy and stear clear.
Tyler
Post by sumgai on Feb 6, 2007 23:20:02 GMT -5
Tyler, And you don't notice any burning sensation at the same time? The blister is caused by the heat given off from the reaction of the adhesive with its catalyst, oxygen. Deposited on your skin in a small area, you may or may not notice anything wrong, beyond the obvious (d'oh! ). I can smell it, as well as feel it, if I get the glue anywhere else beside the pads of my fingers (on particularly clumsy days). I'd say you're probably more sensitive than most, so yeah, stay away from it if you can help it. Or almost as good, use those cheap nitrile gloves they sell at Costco, that'll keep the goop off your skin, yet let you work with all the skill you posess. sumgai
Post by gfxbss on Feb 7, 2007 14:28:53 GMT -5
hmm, got ya. i just have nightmares about when i was 6 and got my first glue together model. it was a nice hospital visit.....
Tyler
Post by gumbo on Feb 9, 2007 4:51:06 GMT -5
Never have a problem with using Superglue..always fixes the problem..
...only downside is sometimes it makes your figers stick to the computer keysssssssssssssssssssssssssssssssss
mikesr1963
Post by mikesr1963 on Feb 12, 2007 9:29:50 GMT -5
Bummer!
Post by lunaalta on Feb 12, 2007 14:32:31 GMT -5
I read that superglue was actually invented/discovered in the early sixties when scientists were looking for a fast acting skin glue. They passed it by 'cos it seemed to stick to everthing quickly......Duuhhhh....... I actually used stuff like that for my split lips in the winter in London in the 60s.
Of course, it was
