Specific OEM Parts Links Apr 17, 2007 16:08:05 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by ChrisK on Apr 17, 2007 16:08:05 GMT -5 This will be a list of links to OEM parts vs those targeted (and hence marked up in price for) the musical products industry.The intent is to have specific links to specific parts and ranges thereof to avoid the need for excessive fishing.Panel Mount 1/4" Shaft Rotary SwitchesAlpha, 1P12T to 6PDT. Use the "next" tab to page thruwww.mouser.com/catalog/629/1375.pdfSpline shaft rotary switches, should/might fit Strat Knobs.JAMECOwww.jameco.com/Jameco/catalogs/c283/P97.pdf1P12Twww.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=101532&2P6Twww.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=101574&3P4Twww.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=101566&4P3Twww.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=101558&
Specific OEM Parts Links Aug 20, 2008 15:38:09 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by ChrisK on Aug 20, 2008 15:38:09 GMT -5 bump for edit
Specific OEM Parts Links Sept 1, 2008 17:07:49 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by newey on Sept 1, 2008 17:07:49 GMT -5 DPDT On-On-On toggle switches (panel mount, solder lug style):Mouser- ESwitchAllied Elec- Cannon SwitchesPartspipe (Hong Kong) on-on-on DPDT ($.98@ USD)
Specific OEM Parts Links Jan 9, 2010 21:00:58 GMT -5 Reply Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by newey on Jan 9, 2010 21:00:58 GMT -5 500KΩ dual-gang pots, audio taper, 1/4" solid shaft:www.mouser.com/ProductDetail/Alpha-Taiwan/RV24BF-10-15R1-A500K/?qs=sGAEpiMZZMtxdMMi52izyvKN9%252b8W2lLSr%252bmDWT8pyW4%3d
