Post by 4real on Aug 31, 2008 11:10:35 GMT -5
Hi...finally got some audio for my latest sustainer telecaster thing so you can here what the guitar sounds like with it's unique pickup combo and OoP option as well as the sustainer in various modes... www.soundclick.com/bands/default.cfm?bandID=869409Here is a run down of the audio... I think this guitar has a good range of usable and balanced sounds and as you can hear, the guitar is very quiet...so I must have learned something here pete
Post by newey on Aug 31, 2008 12:50:07 GMT -5
4Real- Very nice sounds, nice playing, and as you say, quiet! Your post is a perfect example of why the "Sound Samples" board was set up . . . and also why I moved it from Electronics and Wiring! Also nice Vibrato (err . . .Tremo'Leo) work. I've found I like my Teles better than my Strats simply because they don't have a vibrato bridge. But maybe if I actually used it once in a while I'd change my mind. One more thing to practice . . .
Post by crazymanandy on Aug 31, 2008 12:51:55 GMT -5
Very cool! Tasty licks too. I was wondering when you would post it over here for all the Nutz.
CMA
Post by 4real on Aug 31, 2008 13:15:40 GMT -5
Well...it's like 4am down here...so you got it as fast as everyone else. That is just one guitar by the way...there are no overdubs. With a new battery it won't sound so fizzy...
I might get the other half of the inprov up that demoed some of the more bizzare Sci-fi kind of effects...there is a limit to the download so it cuts off short, but I guess that is enough.
Thanks for the complement, I am still getting the hang of the tele thing and I have been playing a lot more chordal stuff that is creaping into my...errrr...style!
pete
Post by crazymanandy on Aug 31, 2008 13:18:38 GMT -5
I meant the guitar itself, not just the sound clip. Or did you already post the guitar here? But it doesn't really matter. Tasty licks, that's all that matters! CMA
Post by 4real on Aug 31, 2008 23:19:46 GMT -5
Post by ashcatlt on Sept 5, 2008 14:09:00 GMT -5
Took almost a week, but I finally got to check it out.
You've got some really great sounds from the pickups themselves. Of course, I was mostly interested in what the sustainer does. Seems exactly what I'm looking for. Very nicely emulates the interaction of a guitar in the same space as a real (loud) amp.
Thanks a bunch and a half for posting this, in fact +1!
Post by 4real on Sept 5, 2008 21:03:00 GMT -5
Thanks...I am glad if it got a little of what I have tried to do with it across. That was recorded after midnight with a dry clean sound with headphones...it reacts with an amp at any volume and with effects like distortion and compression with even better results.
As a recording tool, or to explore these potentials at low volume and with complete control it really is excellent and in the right hands I am sure some amazing things could be done with it.
My favorite effects with it are more subtle...there is a hint of it where notes fade out to harmonics. This is done with very low drive and is very touch sensitive especially with an amp. Often it is the subtle things.
The main attributes is the predictability and control it affords and the ability to do these things at any level or sound without compromising technique. In practice, it does give the sense and feel of a very loud guitar and that in itself can inspire a different way of playing.
One must be wary of over using it though, and now that I am playing with a sustainer guitar again, it is important to know when to turn it off!
thanks again...I will try and put some shorter examples of some of the other things it can do in the nearer future...
pete
Post by warmstrat on Sept 25, 2008 8:50:26 GMT -5
Did you say that the sustainer uses the neck pickup by default?
I thought that was impossible... ?
Post by 4real on Sept 28, 2008 20:29:47 GMT -5
Opps...you are right of course...it uses the bridge pickup by default...if the neck were on it would squeal (oscillate) uncontrollably... After playing the guitar a lot, the neck SCn pickup is my favorite sound...that and the neck and bridge combination which is the most versitile. The bridge pickup has a big brash sound that would be great at volume in a rock context and does do the bright tele twang with a little more refinement. I also wired the volume pot without any treble bleed and turning it down a notch (it is a fairly high output) it takes the edge off and puts a nice mellow feel to the sound...kind of steve cropper rhythm sound. Normally I don't use the volume control that much but not using a treble bleed can be a good thing on a bright guitar like this. Typically when wiring something that I think/know there are going to be problems, I wire the volume and output and attach things one at a time and test through an amp picking up and solving the problems as they occur. It helps with the sustainer switching to know that the guitar is doing what it should before you start messing with that...with this guitar I had been playing it for a bit before adding the phase switch...and a little more before I even thought of putting on a sustainer. Also...voting has started in the GOTM... projectguitar.ibforums.com/index.php?showtopic=38357&pid=395622&st=15entry395622It started well running a dead heat with the acoustic and the metal machine...but both have run away with the tele 11, metal 19 and acoustic 26! Coming up fast behind is an explorer 9. What a month to enter...two 335 type guitars and a host of others have fallen behind that in a very strong field. pete
