Post by ashcatlt on Sept 6, 2008 17:48:28 GMT -5
I almost had to get out of bed at 04:00 today to post this question. What was that was said about "no life"?
It seems to me like current, being a member of Ohm's gang, deserves to be represented by its own initial letter. Much more than capacitance, I'd think. So why not? Is it possible that we discovered capacitance, and started calling it C, before current? Who chose I, and why? Is it some Latin thing? (Darn you Menudo!)
If we freed up the I, we could apply it somewhere it makes more sense. I'd vote for impedance. Its DC alter-ego gets to use its own name, after all. Inductance would seem slightly less important. But then, why do we call that L? Menudo again? Why not H? It's closer in the alphabetic sequence to I, and represents the typical unit of measure for this parameter. Of course, this might lead to confusing statements like H = xH (where x is some non-negative real number), which can only be true if H = 0. But, you know, we do this with voltage all the time and nobody complains.
So, what's up? I'd be willing to bet that sumbody around here knows the answer, but since he's not likely to drop by just to answer my question, maybe somebody who's name starts with capacitance and ends with kiloohm (or is that cathode)? Of course, I'll take the answer from anybody.
Post by andy on Sept 6, 2008 20:00:20 GMT -5
B+S=C.
Bed
Sleep
Chill.
The English language is a peculiar thing. It often doesn't make sense, and it isn't likely to start to do so- as a part time insomniac myself, I'd recommend a spot of chamomile tea!
Post by ChrisK on Sept 7, 2008 0:36:54 GMT -5
There are effects and units thereof. "I" is current, its units are Amps after Andre-Marie Ampere, "E" is potential, its units are Volts after Alessandro Volta, "R" is resistance, its units are Ohms after Georg Ohm "P" is power, its units are Watts after James Watt, "C" is capacitance, its units are Farads after Michael Faraday, "L" is inductance, its units are Henrie's after Joseph Henry, Tungsten was first called Wolfram, (not the Stephen), and still is in many countries. Plumbers are called so since plumbum is the Latin word for lead (and Pb is its symbol). This still doesn't explain the crack thing. Effects were discovered in many countries/languages a'planet and ascribed designations meaningful therein. First is first. Will things ever change? Nope! After all, the gauge of rail lines are descended from the gauge of roman wagons and chariots, all derived from the width of horse's asses. Names are like concrete, once set.......................
Post by ChrisK on Sept 7, 2008 0:38:41 GMT -5
You've heard of the dyslexic agnostic insomniac that stayed up all night wondering if there was a dog.................
Post by lpf3 on Sept 7, 2008 9:28:40 GMT -5
I guess this explains why we drive on the parkway and park on the driveway ...........
-lpf3
Post by ChrisK on Sept 7, 2008 11:35:20 GMT -5
"I had a friend that lived on the medial strip on an interstate highway. It was ok, but when you reached the end of his driveway, you'd better be going 65 mph."
Stephen Wright
No one ever claims to be a part-time somniac.
Post by andy on Sept 7, 2008 18:58:28 GMT -5
No one ever claims to be a part-time somniac. Apart from the occasional narcoleptic?
Post by D2o on Sept 7, 2008 21:09:42 GMT -5
Oh, ash - sumgai would love this post - don't you think? Particularly coming from you.
Post by newey on Sept 8, 2008 7:55:58 GMT -5
Thus explaining Interstate highways in Hawaii . . .
Post by andy on Sept 8, 2008 9:01:58 GMT -5
...and certain products of a certain guitar manufacturer...
Post by ChrisK on Sept 8, 2008 18:35:19 GMT -5
"Hardware is concrete and software is velcro.)
Post by Teleblooz on Sept 23, 2008 21:01:35 GMT -5
"E" is potential, its units are Volts after Alessandro Volta More properly, "E" is for Electromotive Force, or EMF, thus explaining the initial. Haven't figured out the current thing yet...
