Post by cynical1 on Jan 12, 2009 1:26:59 GMT -5
Greetings -
Well, after 25+ years my old AKG finally gave up the ghost and I'm mic-less at the moment.
Right now I'm trying to record the bass directly into the PC with a BP-80 through an old Bass Rockman to boost the signal...but it just ain't the same.
I have no PA, board or recording deck anymore, or any way to amplify the mic signal...just the old PC and Soundblaster card...
Does anyone out there have a recommendation for a good kick drum/bass mic (or warnings on a bad one)...that isn't going to break the bank? I'm cool with used, but it's been ages since I've bought a mic and would appreciate any input based on someone else's hard earned experience...
Thanks
Happy Trails
Cynical One
Post by ashcatlt on Jan 12, 2009 13:24:37 GMT -5
I can't say as I've ever used a mic on a bass cabinet. It's just so much easier to run a DI. Especially in a home recording environment where your room is likely not particularly well treated acoustically. Standing waves alone make this more of a headache than necessary most of the time.
Then, if you're looking to mic the thing you'll also need to find something to use as a preamp to actually get the mic-level low-Z input into the soundcard. The soundblaster style cards do have a preamp, but...
My suggestion, FWIW, is to think about what's wrong with your DI chain and maybe look into an amp simulator type deal that sounds better to your ears. I'm very happy with my Behringer Bass V-Amp. Lots of people who do this for money on a daily basis swear by the Sansamp Bass Driver DI.
Post by andy on Jan 12, 2009 13:49:41 GMT -5
Yes, as Ash says, given that you are recording straight into the soundblaster it may be worth looking into other D.I. options. I tend to use a blend of amp and Line 6 POD (for guitar) which can sound quite good. However, whilst I can't vouch for any particular brand, any mic designed for kick drum will do a good job. But assuming that AKG was a D112, you probably know that already!
Post by cynical1 on Jan 12, 2009 17:15:46 GMT -5
Actually, it's an old D12 mic...probably older then I am... It's back in the box awaiting better days when I can look into possibly having it repaired.
I'd love to grab a Line 6 or a real DI interface...but any major purchases are on hold. I was toying with the idea of a mini-mic preamp and something used off of eBay, or hoping there was something dynamic out there I hadn't heard of.
What grabs my a__ is that I used to have all of this stuff in abundance...but that old marital bliss creeps in and it all seems to vaporize over time... I envy you guys with understanding spouses...
Well, thanks for the input (pun intended) Guess it's back to the same old for now.
Happy Trails
Cynical One
Post by ashcatlt on Jan 12, 2009 22:42:37 GMT -5
Well, if you're looking to spend little or no money, you could try the old "sub-kick" trick. Take speaker, connect it to a mic pre-amp, done! I hear a 10" or 12" can be great for that really deep low end. I'd imagine something (much) smaller would do as well as a 57. May not sound good, but it might sound funky! Believe it or not, somebody actually sells these things.
Post by gfxbss on Jan 14, 2009 22:39:23 GMT -5
Ash, good call, that was deffinately going to be my suggestion.
the last studio i recorded in, i played through a Grace Pre. sounded great, but i cant say how much it costs. BTW, I play bass in my band....
My personal fav for an electric bass sound is a Shure Beta 52 combined withe a 57. of course, depending on what you consider breaking the bank this may be out of the question.
Also, a D-12, ive never even seen one, but i know i would love to hear anything that you did get to record with it. please let me know.
Thanks,
Tyler
