spower
Post by spower on Apr 21, 2010 17:59:36 GMT -5
can I wire a push/pull to have the coil split in the down pos and buck in the up pos
Post by sydsbluesky on Apr 21, 2010 18:19:05 GMT -5
Sure can. Just reverse the wiring on the switch, sort of... I'd imagine someone will be along shortly with a more knowledgeable answer, but it can be done.
The dean I just finished wiring up has phase reversal on a push/pull and I accidentally wired it backwards... I kinda like it this way, though.
And welcome to the nuthouse! Enjoy your stay, but please don't feed the mods after midnight.
Post by newey on Apr 21, 2010 21:15:41 GMT -5
SBS said: No "sort of" about it, that's exactly what you'll do. A P/P pot has a DPDT switch attached. The two center terminals are the commons, these stay wired exactly as they are. Whatever is wired to the top 2 lugs gets wired to the bottom lugs, and vice versa. As our friend used to say: "Done is".
Post by sydsbluesky on Apr 21, 2010 21:27:55 GMT -5
Aaaaaand there we go!
I can never keep straight how those things are connected in there.
