sko57
Post by sko57 on Sept 7, 2011 11:20:48 GMT -5
Installing TS's in my strat but lost the wiring diagram. Thought the paint spots on the bottom was the pup position, red being the bridge and blue being the neck, any help would be greatly app. Thanx in advance
Post by newey on Sept 7, 2011 17:04:28 GMT -5
sko57-
Hello and Welcome to G-Nutz2!
I don't have an answer to your question, but someone will probably be along soon.
In general, Fender pickups distinguish the middle pickup with different colored wires. Since you don't mention the middle, can I assume you've got that one figured out?
For the others, easiest way to tell is with a multimeter; the bridge pup usually has a higher DC resistance. If they're the same resistance, (plus or minus a few tenths) then it doesn't matter which goes where.
