Post by antigua on Sept 25, 2016 16:34:54 GMT -5
DiMarzio managed to trademark double cream exposed bobbins in the early 80's, and since nearly all aftermarket pickups have been produced by US based companies, DiMarzio has had a monopoly on the double cream racket.
Someone mentioned on another guitar forum that you can find double cream humbuckers from Chinese retail sites, and for dirt cheap. US trademark law doesn't extend to China obviously, so these are completely legal.
And here it is, the Donlis "Sell Free Shipping N&B 1 set Wax potted Cream color 4 output wires Alnico 2 guitar humbucker pickup"
www.aliexpress.com/item/Sel...259823681.html?spm=2114.13010608.0.118.J7Rlob
You're probably thinking, but yeah, they're crap pickups. But are they? I've taken the time to do a detailed comparison between the Donlis neck and the DiMarzio 36th Anniversary neck. I bought two Donlis neck pickups, only because I prefer low output bridge pickups, and I intend to use neck pickups in both positions.
The Donlis cream humbucker is also offered with AlNiCo 2 magnets, you just have to search AleExpress for it. There are quite a few interesting looking pickups, and I hope that be assuaging fears that these pickups are substandard, that guitarists might feel emboldened to mine their offerings. They would certainly be a more unique addition to your guitar than the pickup du jour from Seymour or DiMarzio.
Are the materials of good quality???
The only materials that are electrically relevant is the metal. The plastic parts can support neither a magnetic field, nor an electric current, so they are inert.
In order to compare the quality of metals, I've performed measurements for DiMarzio 36th Anniversary, then transferred the metal parts to the DiMarzio's coils, so that they bobbins and wire are constant, while the metal parts change.
Here is the Donlis beside the 36th Anniversary. The cover will come of for these test to make it an apples to apples comparison.
Lots of wax in the DiMarzio:
Baseplate Comparison
First comes the base plate, and as you can see, the DiMarzio 36th Anniversary is not actually a PAF replica, as they allude to on their website, but a DiMarzio "airbucker", which just means they forego the wood spacer and retaining bar and instead place four plastic washers around two of the slugs and two of the screws. The effect is that there is about 15 to 20% less flux density at the pole and screw tops, which DiMarzio claims mimics the effects of a magnet that has degaussed naturally with age.
Here is the Donlis. As you can see, it uses the more correct spacer / retainer setup, but uses plastic instead of wood, as does Seymour Duncan, and even includes two plastic spacers. The reason there are two spacers is because, unlike the spec PAF, the conductor wire enters the baseplate on the same side as where the two coils hook into the conductor wire, where as original PAFs had the conductor wire entering on the opposite side of the base plate, so the conductor cable spanned all the way across that space along the top. The Epiphone ProBucker happens to be arranged the same way, except they used two wood spacers instead of plastic.
And here is the test being performed, with the DiMarzio coils attached to the Donlis base plate:
Here is the measured result:
The black line is the DiMarzio baseplate. The Donlis shows a resonance about 200Hz greater, and peak difference is only 0.4dBV, which is to say the difference between them is completely inconsequential, and would be impossible to hear.
Slug & Screw Comparison
In the picture below, the DiMarzio and its screws are far left, the Donlis is in the center, and a Gibson 57 Classic is on the right. The Donlis' fillister screw heads match the Gibson 57, where as the DiMarzio's screws have slightly smaller heads.
The way this test was performed was similar to the plate; first the DiMarzio was measured as-is, then the Donlis' screws and slugs were transferred into the Diarzio's coils, and then the measurement it taken again. For this test, there is no base plate under the coils, though I kept the AlNiCo 5 bar in place because, along with the wax, it was helping to hold things together.
4
The difference here is 60Hz and 0.4dBV, even less difference than was seen with the base plate swap, and that's really saying something, since these are core materials. Again, the differences are of no consequence, audible or otherwise.
</article>
