Post by antigua on Dec 19, 2016 3:37:28 GMT -5
www.tonerider.com/pure-vintage
After realizing that the Tonerider AlNiCo II Blues were just as hot as the previous pickups I was trying to replace, because despite the lower DC resistance, the AlNiCo 2 rods cranked the inductance up higher than I had imagined it would, I bought Tonerider's no BS vintage Strat set.
The set features a modern stagger, a nice touch that a lot of the bigger pickup making companies are still not fully willing to embrace.
I haven't heard them in a guitar yet, so this is just a spec analysis, and they look very promising.
Specs:
Tonerider Pure Vintage Strat Set - Bridge
DC Resistance: 6.62K
Inductance: 2.597H
Calculated C: 96pF (106-10)
Coil width: 0.5475" (with tape)
Resonant Peak: dV: 15.9dB f: 9.59kHz (black)
Loaded (200k & 470pF): dV: 6.5dB f: 3.94kHz (red)
Tonerider Pure Vintage Strat Set - Middle
DC Resistance: 6.55K
Inductance: 2.431H
Calculated C: 103pF (113-10)
Coil width: 0.5310" (with tape)
Resonant Peak: dV: 14.8dB f: 9.59kHz (green)
Loaded (200k & 470pF): dV: 6.5dB f: 4.03kHz (gray)
Tonerider Pure Vintage Strat Set - Neck
DC Resistance: 6.12K
Inductance: 2.285H
Calculated C: 91pF (101-10)
Coil width: 0.5370" (with tape)
Resonant Peak: dV: 15.0dB f: 10.5kHz (pink)
Loaded (200k & 470pF): dV: 6.5dB f: 4.27kHz (black)
Pole piece strength: 750G- 950G, Bridge G-B-E: 700G-900G
Bode plot:
The loaded peaks right around 4kHz, and 4.27kHz makes these genuine "vintage output" pickups. Seymour Duncan SSL-1, by contrast, measured loaded peaks of 3.81kHz.
A remarkable thing about these pickups is the low capacitance, with two of the pickups coming in under 100pF. In general, only the boutique winders tend show such low capacitances. Most of Fender's Strat pickup measure between 120 and 140pF.
Tonerider's twist is that they use AlNiCo 3 for the three higher pitched strings on the bridge pickup. This is the same scheme Seymour Duncan uses for their "Five-Two" set, though there's are with AlNiCo 2.
Even though most all of the other pole pieces are supposed to be AlNiCo 5, I measured only 750 to 950 gauss on all the pole pieces, instead of the usual 1050G. I recharged a few of them with a neodymium, then waited fifteen minutes, after which point the three measured 1020G, 950G and 1050G. There must be something a little off about this AlNiCo 5, it's very unusual to see such random deficits in flux density with AlNiCo 5 pole pieces. Personally, I'm all for something different, though. A lot of boutique pickup makers boast that they "hand calibrate" their magnets to faux-age the magnets, and though I've never seen this actual bear out in measurement, what I'm seeing here does correspond to AlNiCo 5 that has become weaker with age. The only downside to unstable AlNiCo 5 is that it will lose charge more rapidly over time, eventually becoming so weak that it's detrimental to the tone, as though you set the pickups very far away from the strings.
Tonerider says:
"A 999-step CNC programmable coil-winding machine and custom wire tensioning system are used to create looser, more random coil structures. Even the magnets are custom made, hand-bevelled and then charged and de-charged in a special sequence."
It seems to me that the low capacitance and the interesting AlNiCo 5 observed might be proof of these claims. I must say... it's nice a surprise to see such promises delivered upon. It seems that they really have programmed a CNC machine that makes a coil with a lower capacitance.
Specs:
Inductance: 2.597H
Inductance: 2.431H
Inductance: 2.285H
Bode plot:
Tonerider says:
