Post by someguy on May 27, 2019 15:52:06 GMT -5
Hello Guitarnutz,
I'm working on a custom wiring using two Zexcoil Convertible pickups. Each of the pickups has six coils (one coil per string) organized as 2 sets of 3 coils, which can be wired to get two basic voices: series (humbucker-ish) and parallel (single-coil-ish). (Basically the same options as a normal double-coil humbucker, except coil-split is useless, because it only picks up half of the strings.)
My current schematic utilizes two 3PDT switches for series/parallel switch (one for each pickup) and a 5-way superswitch (4P5T, only 2 poles are used so far). For pots, I plan to use master volume and master tone. I often find the difference between series and parallel modes a bit too drastic, so I add a resistor in parallel mode to tame the resonant peak a bit. More importantly, I'm also trying to bridge the gap (in terms of resonant frequency) between the basic voices by adding extra voice options:
- To get a darker tone in the parallel mode, a capacitor (and a resistor to avoid the resonant peak becoming too sharp/honky) is added in parallel to the pickup
- To get a brighter tone in the series mode, the opposite pickup is blended in parallel using a fixed resistor. This allows me to increase the resonance frequency without getting much phase cancellation (as in normal two-pickup middle position).
I use the 5-way switch positions 2 and 4 for these extra voices, while the series/parallel switches determine which voice to use, so the positions are:
1. Neck
2. Neck with Bridge blended in (if Neck is in series mode) or Neck with extra C and R (if Neck is in parallel mode)
3. Neck and Bridge in parallel
4. Bridge with Neck blended in (if Bridge in series) or Bridge with extra C and R (if Bridge in parallel)
5. Bridge
Here's the schematic from NI Multisim:
- R2 and R4 are 'blend' resistors for bridge and neck pickups respectively
- R1 and R6 attenuate the resonant peak when in parallel configuration
- C1 and R3 move down and further attenuate the resonant peak in parallel configuration in positions 2 and 4
As you can see, currently in positions 2 and 4 of the 5-way, the position of the opposite pickup's series/parallel toggle affects the result. However, I've found that blending in the Bridge in parallel mode to the Neck in series (and vice versa) isn't of much use, as the resulting tone is rather dull (no resonant peak).
Finally, to the question: is it possible (given the remaining poles of the superswitch) to somehow 'automatically' bypass the series/parallel toggle and put the pickup in series mode, if it's used as a 'secondary' pickup in positions 2 and 4?
Thanks!
1. Neck
5. Bridge
Thanks!
