Post by frets on Jan 6, 2020 3:09:16 GMT -5
Hey Guys, I usually use one of those mechanical pump solder suckers; however, I need something better. I’m looking at desoldering stations and am unfamiliar with the technology. Any recommendations would be appreciated. Thanks!
Post by JohnH on Jan 6, 2020 6:33:27 GMT -5
Post by frets on Jan 6, 2020 12:38:49 GMT -5
Thanks John
Post by thetragichero on Jan 24, 2020 3:44:47 GMT -5
techspray pro wick desoldering braid with a bit of flux I'll use the bulb for big stuff and then the braid for finer stuff
Post by frets on Jan 24, 2020 13:53:47 GMT -5
Thanks Trag, I got the bulb after John recommended it. I will buy the pro wick you recommended.
Post by JohnH on Jan 24, 2020 14:51:21 GMT -5
I find the bulb is kind of magic! I expected that it would get most of the bulk off, but leaving an annoying bit behind. But the molten solder seems to have some kind of stick-together viscous group-mentality such that once most of it is moving it all follows. I've had leads through pcbs that have been completely freed by one suck.
Post by frets on Jan 24, 2020 18:01:11 GMT -5
Hi John, You are exactly correct. The bulb is superior to the cheap soldering vacuum pen I was using. I’ve cleaned a shoe box of parts no problems. Thanks again to you and Trag
Post by b4nj0 on Jan 24, 2020 19:05:40 GMT -5
The rubber bulb sucker gets a thumbs up from me too. I can't control the recoil on those piston types.
e&oe ...
