Post by Deleted on Jan 14, 2020 5:55:37 GMT -5
What does the Upload File button do in Messages as i cant get it to work
been trying to send Photos (CLEAN ONES!!) and end up Uploading to Facebook and then linking them back in!
Post by newey on Jan 15, 2020 12:50:19 GMT -5
reTrEaD has your backAs stated there, there are two options, either of which is easier than what you're doing. First, you can use the "Add image to post" feature, which works through imdbb. Second is to use(as you were trying to do)the "Upload file" button, which works through Cloudinary. However, you must first set up an account with Cloudinary, then link to that account with your profile here. Detailed instructions to do this are in the link above.
