cem
Post by cem on Jul 4, 2020 17:20:46 GMT -5
Hello people I have a set of these pickups and i like them a lot. What bothers me though is the lack of a RWRP middle. Could you guys recommend a pickup that is similar in character? Seymour Duncan SS-1 vintage staggered pickup seems like a good choice. It seems higher in dcr on paper though. Would it still be a good choice? What do you guys think?
Post by newey on Jul 5, 2020 8:24:29 GMT -5
No opinion on the SS-1, never used those. But if you really like the Fender 57/62s, you can DIY a RWRP middle. You will need a compass (a cheap toy one will suffice) and a fairly powerful neodymium magnet. There are tutorials on the web showing how to do this, basically you find whether the coil is north or south with the compass, then find the opposite pole for the magnet, and apply the magnet to each pole piece (opposites attract and all that) for a few seconds, then double-check with the compass that the magnet has been repolarized.
Then you simply reverse the wiring of the middle pickup, this takes care of the "RW" part of the equation.
cem
Post by cem on Jul 6, 2020 16:35:20 GMT -5
newey you are awesome I actually knew about this concept but for some reason i had come to the conclusion that the magnets were unobtainable in my country. But it turns out they are quite common and cheap. Thanks to you the cost will be at least 10 times cheaper.
Post by newey on Jul 7, 2020 10:56:41 GMT -5
Just remember to keep that magnet away from the other pickups, other guitars, or any hard drives, USB drives, etc. Since you have to reverse the wiring anyway, it's probably safer to disconnect the middle pickup and remove it from the guitar prior to remagnetizing the pole pieces.
Post by ziggystardust723 on Feb 1, 2021 21:44:56 GMT -5
Hello Cem, What did you finally.? To Change the Magnet Polarity is the most Simple, > with Neodymium Magnets: -Commanded on the Net, > I'd done it 2 times ('cause the 2 1st dyed: hurting each other & where destroyed.. so you've to take care) & got 2 to Charge the New Rod-Magnets: = 'cause when you Bye them, they're Not Charged.. - You have to Ask them on a Chinese or Japanese site.. - Then, Not to Rewind the Pickup: > Just Inverse the Electrical sides, = Inside Black Wire (on Left) to + = & 0utside Wire White or Yellow to - - That's All: your Middle is RW/RP.! Then you Get No Buzz for Neck/Mid & Bridge/Mid: = 'cause they're in // (6+6k = 3k) > But Lot of People Forget than in Serie mode: 6+6k = 12k.. > For Bridge & Mid 0nly.. - Tell us what you finally did.. & 0thers interested: If they try to do this, really Cheapper to do Yourself, & not have to Bye an 0ther pu. - Bye, Ziggy (France, 3h44)
