Post by frets on Oct 27, 2021 19:39:53 GMT -5
Hi Guys, Did a variation on the Fat Strat today. Added a 4-Way Varitone. This is the 2 Volume version with 5-Way Superswitch for Series, Parallel, Out-Of-Phase with the push pulls allowing independent Coil Splits. Here it is. I used small PIO tone caps. Again, the audio signal transformer that I use in tight spaces are these small SMD 600:600 1.5H ones that can be found on AliExpress for about $3 a piece. I find that they range from 1.2H to 1.7H with the vast majority being the exalted 1.5H.
