Post by Deleted on Apr 27, 2022 5:01:51 GMT -5
Post by newey on Apr 27, 2022 5:15:04 GMT -5
Cost is not bad, pretty sure the price is just for one.
Not sure what use a 20KΩ pot will be in a guitar (but I assume these are for some sort of modification, knowing you @angellahash). These also have a 30mm shaft, they are made to be mounted to a chassis like on an amp and then have the knob protrude through a faceplate. This will likely be too deep for a guitar cavity. You could cut the shaft down on the ones without the switch, but not on the ones with the switches.
Also not clear what type of switches are on the switched ones, I can't tell if it's a regular DPDT like a push/pull or maybe just a SPST on/off
Post by Deleted on Apr 27, 2022 5:36:06 GMT -5
Take as much apart and see what can be changed
I like the two controls
So your right for what I want it for.. the 20k I feel I can change if I want ..
The size we'll see what can do and work from there
