Post by frets on Jul 25, 2022 20:51:44 GMT -5
Some time ago, I posted an updated Spin-A-Split Diagram. I left out the Ground Wire and with inspection of the original, noticed the NF and SF were reversed. This is correct and verified. I just put it in a guitar today.
Post by sumgai on Jul 25, 2022 23:59:35 GMT -5
Good work, frets! Now go back and edit your previous post/thread, pointing readers to this correction. Then go have a beer on me! sumgai
Post by Deleted on Jul 26, 2022 2:25:27 GMT -5
UP you have shorted NF and NS together and SF and SS together on Ground.
DOWN, you in Series but there is a POT around the South Pole
I find the easy way to look at these circuits is to cover up one side
Post by stevewf on Jul 26, 2022 11:27:21 GMT -5
Waitasec,
If the labels SF, SS, NF, NS mean "SouthFinish", "SouthStart", "NorthFinish", "NorthStart".... then according to the new diagram, doesn't pulling up on the knob just short both coils? Or does my admittedly rookie brain need a kick adjustment?
Post by frets on Jul 26, 2022 13:13:35 GMT -5
Doesn’t do that. I’ve got it in a guitar.
Post by newey on Jul 26, 2022 14:08:55 GMT -5
If the labels SF, SS, NF, NS mean "SouthFinish", "SouthStart", "NorthFinish", "NorthStart".... then according to the new diagram, doesn't pulling up on the knob just short both coils? Or does my admittedly rookie brain need a kick adjustment? frets, stevewf, @angellahash In reality, I suspect it works because frets wired it correctly, but then mistakenly swapped SF and NF when she did the diagram. If NF is wired where SF is shown on the diagram, and vice versa, then all will be well in Spin-A-Split Land.
Post by frets on Jul 26, 2022 15:32:49 GMT -5
I owe you guys an apology. I have severe ADD and as Newey and the gang well know, I do mis-diagram from time to time. But my intentions are good. I will fix😸 Please forgive me Steve and Angellahash. I was arrogant and haughty taughty.
Post by frets on Jul 26, 2022 15:39:03 GMT -5
God, tell me I havve this right. I can do it when I'm wiring
Post by Deleted on Jul 26, 2022 16:24:31 GMT -5
One day I'll get you to use circuit diagram icons than these 🤗
Post by frets on Jul 26, 2022 19:06:41 GMT -5
Angel😺,
I don’t think that’s ever going to happen. I think too visually and literally. I wish I could do it.
Post by stevewf on Jul 27, 2022 20:48:56 GMT -5
For what it's worth, Verified Version #2 looks good to me. In this case, I'm reading that it's the South coil that gets "Spun Out", i.e. shorted to ground, as the knob gets turned toward zero. Also, that the two coils will hum-cancel if they're a typical RWRP pair, like in a humbucker. Thanks for posting so much, frets. I really enjoy seeing your stuff, especially photos of your actual soldering, and, aside from that, I'm thrilled that Girl-Tech gets so many clients.
