Post by frets on Sept 23, 2022 16:47:23 GMT -5
Hi Guys😸😸😸 I saw the post regarding how to connect a Xicon/Mouser Audio Signal Transformer within a passive treble bass midrange configuration. I also wanted to post how to connect other audio signal transformers that are not Xicon/Mouser (e.g., Chinese).These transformers come in a couple of color/lead types. You have to know what you are looking for in order to get the Henries you need. Also, you have to connect them a little differently from the Xicon/Mousers in order to maximize Henries. I also illustrate how to connect a common Chinese SMD Audio Signal Transformer. These vary in Henries from 1.2H to 2.0H. Sorry for the “out of order,” every time I load photos they are always out of order.
Post by unreg on Oct 6, 2022 1:14:48 GMT -5
Hi Guys😸😸😸 I saw the post regarding how to connect a Xicon/Mouser Audio Signal Transformer within a passive treble bass midrange configuration. I also wanted to post how to connect other audio signal transformers that are not Xicon/Mouser (e.g., Chinese).These transformers come in a couple of color/lead types. You have to know what you are looking for in order to get the Henries you need. Also, you have to connect them a little differently from the Xicon/Mousers in order to maximize Henries. I also illustrate how to connect a common Chinese SMD Audio Signal Transformer. These vary in Henries from 1.2H to 2.0H. Sorry for the “out of order,” every time I load photos they are always out of order.Is this the order you were looking for?: —- If so, then you should know that postimg always causes their photos to appear with a link… the images are always “clickable” so just delete the link part. Linked images in html are coded like: <a href=“…url…”><img src=“…server path…”></a> The “a” tag is the link. The “img” tag is the image. And the “/a” tag is the closing “a” tag. proboards, and tons of other php forums, substitute [] for <>. tl;dr: So, just remove each set of [a…] and [/a] tags; or just copy cut paste each [img…] tag to wherever you need it. I quoted your entire post so you could simply check my post source and learn from it… that’s, obviously, only if this attempts to solve your problem in bold.
