JackFawkes
Post by JackFawkes on Nov 14, 2022 4:08:28 GMT -5
This is the second draft of my first ever attempt at a wiring design, and a good but more complicated than the regular Strat wiring I'm familiar with. Please scrutinize the heck out of it! I especially want to make sure that all of the switches actually function the way that I've indicated, and that the PTB wiring is correct. When researching PTB diagrams, I found a few slight variations in how the Treble-cut was wired, and also some that put Bass-cut before Treble-cut. Because of those variations, I don't feel completely confident with what I've drawn here. Two additional questions: 1. Would a Treble Bleed be a worthwhile addition? If so, would parallel 150K//1nF be good values to choose? 2. Would it be advisable to do a "Half" Out of Phase switch on the Neck? If so, would 10nF be a good value to choose? Thank you all so much for your knowledge and insight! Jack
Post by newey on Nov 14, 2022 5:58:32 GMT -5
JackFawkes- You didn't specify the type of switch you're using, so I'm assuming that these are 4-position slide switches? Double-pole, On-On-On-On? If so, your diagram looks correct as far as the pickup switching goes. As far as what's the optimal PTB set-up, I'll leave that to others.
JackFawkes
Post by JackFawkes on Nov 14, 2022 10:54:27 GMT -5
You didn't specify the type of switch you're using, so I'm assuming that these are 4-position slide switches? Double-pole, On-On-On-On? If so, your diagram looks correct as far as the pickup switching goes. Ah nuts, I didn't specify clearly enough... but yes you are correct, they're DP4T On-On-On-On slide switches.
Post by Deleted on Nov 15, 2022 14:33:49 GMT -5
Might be easy if you said which one was Common pins
Post by newey on Nov 15, 2022 20:54:08 GMT -5
Might be easy if you said which one was Common pins These are slide switches, remember. Adjacent lugs connect, there are no common lugs.
JackFawkes
Post by JackFawkes on Nov 16, 2022 1:39:33 GMT -5
Sorry, I really should've specified they were slide switches on the diagram. I crudely tried to imply it by using underlines to sort of compartmentalize each setting to their respective poles... ...but that was a pretty poor way to convey it Jack
