shift
Post by shift on Dec 29, 2022 2:03:40 GMT -5
Hey there. I have a HSS strat with an s1 that just splits the humbucker. I've been dabbling in modding my guitar and I've had this idea but I don't really know how to make it work What I'm looking for is -
Position S1 not pressed
1) Bridge
2) Bridge + Middle (parallel)
3) Middle
4) Neck + Middle (parallel)
5) Neck
Position with S1 Pressed
1) Bridge (coil split)
2) Bridge (coil split) + Middle (parallel)
3) Middle
4) Neck + Middle (series)
5) Neck
If anyone could help that would be awesome
Post by newey on Dec 29, 2022 11:40:46 GMT -5
shift- Hello and Welcome to G-Nutz2!Was this the stock wiring scheme? If so, we may be able to use the stock wiring diagram as a starting point. If you rewired it yourself, or added the S-1 yourself, do you have a diagram of what you did? I assume that your description of positions 1 and 2 with the S-1 pushed (i.e., bridge split HB) is the same as it is now, and that the only change you want is, therefore, at position 4, where you want series instead of parallel neck and middle? (There is no standardized way of designating series versus parallel connections, but we tend to use a "+" for parallel and a "x" for series, so we would normally write your position 4 as " N x M"). At first blush, I think what you want to do can be done with the S-1, but before we put pen to paper, working from the wiring you have now will simplify things considerably.
Post by newey on Dec 29, 2022 12:45:38 GMT -5
At second blush, well of course it can . . . In the absence of knowing exactly how your HB is wired to the S-1 now, I had to make some assumptions. First, I'm assuming that your 5-way switch is the standard Strat-type 5-way switch, not a Superswitch or some other type. Also, the numbering and designation of which poles are used is arbitrary- I show your HB as being wired into Pole 1, but any of other the other poles might have been used instead. Assuming your HB wiring looks like my diagram on one of the poles, whichever it is, then you should be able to adapt my diagram accordingly. Just pay attention to the "A" and "C" lugs as the up and down settings need to be consistent from pole to pole. And, as I always say, I make my share of mistakes (perhaps more than my share . . . : , so let's get other eyes involved here before you fire up the soldering iron.
shift
Post by shift on Dec 29, 2022 18:43:04 GMT -5
Whoops I should've added my current scheme. Pickups are Seymour Duncan for the color code. Sorry for the crude drawing.
Post by newey on Dec 29, 2022 23:41:57 GMT -5
OK, so it's a regular 5-way switch. My drawing should be fine, but again, let's get a second opinion. On the diagram you posted, the third lug of the volume pot seems disconnected, and I can't really see how that coil split is wired. Also, the N/M tone pot isn't connected to anything. I didn't know whether you omitted those things just to focus on the switching, but just so we're clear.
Post by reTrEaD on Dec 30, 2022 8:48:15 GMT -5
OK, so it's a regular 5-way switch. My drawing should be fine, but again, let's get a second opinion. I don't see a way of getting what shift specified in his OP with a regular 5-way. For instance, what happens in position 3 of the 5-way, when the S-1 connects the (+) of the Middle pickup to make a series link with the (-) of the neck pickup rather than to lug 2 of the 5-way? Looks like no sound in that position. You could probably accomplish the goals using a superswitch but I haven't worked that out to be certain.
Post by newey on Dec 30, 2022 9:31:48 GMT -5
reTrEaD is right, with the S-1 pushed, positions 2 and 3 will be dead. I didn't spot that. Ugh. Thought I had it.
Post by sumgai on Dec 30, 2022 15:59:30 GMT -5
newey, Sorry to have to say, you made the same error about the standard 3-way switch way back in March of 2012. But don't worry, old age and loss of memory can happen only once in a person's life, so you're good to go! HTH sumgai
shift
Post by shift on Dec 30, 2022 17:44:34 GMT -5
So I opened up my guitar to make sure what I actually had wired up to what, so here's and updated picture I also did try it the way you diagramed it and yeah there's a few dead spots. I don't mind buying a Super Switch if that'll help with the build
Post by MattB on Dec 31, 2022 2:12:50 GMT -5
I think this will work.
With your current wiring scheme, both tone controls are active in position two. With this scheme, only one control can be active in position two. I made it the bridge control, but it could be either. If you really want to have both tone controls working in position 2 it can be done. I think you would need a Fender Discrete 4 pole switch, which is probably a bit more expensive and harder to find than a regular superswitch.
Post by Yogi B on Dec 31, 2022 20:06:41 GMT -5
If you really want to have both tone controls working in position 2 it can be done. I think you would need a Fender Discrete 4 pole switch, which is probably a bit more expensive and harder to find than a regular superswitch. I agree that it could be made to work with Fender's "Discrete" switch, but you can also make it work with a normal superswitch by wiring the bridge tone pot permanently in parallel with the bridge pickup.
It's mostly irrelevant in this situation, since we have the four poles of an S-1 switch, but I think there's a way to get the same result using only a DPDT. Schematic to follow... EDIT: (This also shows the moved bridge tone control.)
Post by jhng on Jan 4, 2023 11:11:34 GMT -5
Hello -- Just a quick point which hasn't been mentioned. When using the standard Fender 5-way, it is generally much easier to do series combos in positions 1, 3 or 5.
So, if Shift was willing to consider having the NxM combo in a different position on the switch, it could be much easier and with no need for different or extra parts. E.g.
Alternate positions:
1) Bridge (SC) 2) Bridge (SC) + Middle (parallel) 3) Middle 4) Middle 5) Neck x Middle (series)
That can be done by using a spare pole of the S1 switch to move the ground of the Neck pickup from ground to the hot of the Middle. A relatively minor tweak to the existing wiring with no extra parts.
Post by bushwackermark on Jan 17, 2023 6:07:24 GMT -5
jimcorliss
Post by jimcorliss on Feb 23, 2023 19:52:13 GMT -5
How did it turn out ? Thanks,
