frednugent
Post by frednugent on Feb 10, 2023 22:20:40 GMT -5
Hi guys,
I wasn't getting any responses so here is my revised post. I'm looking to load a Strat with 2 P90's and 4-Way Switching:
1. Bridge 2. Neck & Bridge in Parallel 3. Neck & Bridge in Series 4. Neck
I would like to have a Volume, Tone and Bass Roll off as I often find myself using the neck pickup for the fat tones but wishing I could roll off a bit.
I can follow a wiring diagram but I'm too green to construct one, at least reliably. I'd greatly appreciate some help.
Thanks
Post by newey on Feb 12, 2023 23:22:51 GMT -5
Here's a schematic to do what you want. I'm sure there's a wiring diagram to do this around here somewhere, I just have to find it. This is essentially the Fender "Baja Tele" wiring, but the Baja Teles used an S-1 switch to include a phase option. This version just uses the 4-way lever switch. sumgai's 4-way Tele schemeAs for adding the bass cut, that will be a module to be inserted into the tone circuit. We have a number of diagrams around here showing that, it will be wired into your scheme the same way as the others. So, if we can get you squared away with a diagram, the bass cut module is an easy addition.
