Post by David Mitchell on Apr 21, 2023 10:00:43 GMT -5
This is the simplest of a few schemes I've been working on for my guitar — hoping to attempt it very soon, and work my way up later.
The points of interest, I suppose, are that I intend it to have a global (overriding) series switch on the volume push-push pot, and a DPDT to switch between two different caps or bypass. I'll be experimenting with the values. I have a Redeemer buffer, which isn't particularly important to this scheme, but may be moreso later, and I want to have an option that's something like typical cable capacitance, and another that will modify the Filtertron response to something like that of a P90 (based on GuitarFreak modelling). That's beside the point, but in case anyone's curious what it's for, there you go. I think I put the DPDT upside down compared to what I actually want, but that's easy to reverse physically. (I do wish DIYLC had hints about switch terminal connectivity and toggle position.)
What say the experts?
Here's DIY Layout Creator's analysis:
If anyone has suggestions for a better diagram, I'm also open to suggestions there!
Switch configuration: [Pickup Selector.Middle:Series/Parallel.ON1:Tone Switch.ON1]
Parallel/Series connectivity tree: ((Volume.1-2 + R2) + (C2 || R3)) || (Volume.1-2 + ((Bridge.North<- + Bridge.South<-) || (Neck.North<- + Neck.South<-))) || Volume.2-3
Notes:
'Bridge' and 'Neck' pickups engaged, wired in parallel
'Bridge' pickup wired in humbucking mode with series coils
'Neck' pickup wired in humbucking mode with series coils
All pickup coils are wired in-phase
This configuration is hum-cancelling
Switch configuration: [Pickup Selector.Middle:Series/Parallel.ON1:Tone Switch.ON2]
Parallel/Series connectivity tree: (Volume.1-2 + ((Bridge.North<- + Bridge.South<-) || (Neck.North<- + Neck.South<-))) || Volume.2-3
Notes:
'Volume' potentiometer acts as a volume control for 'Bridge' and 'Neck'
Switch configuration: [Pickup Selector.Middle:Series/Parallel.ON1:Tone Switch.ON3]
Parallel/Series connectivity tree: (Volume.1-2 + ((Bridge.North<- + Bridge.South<-) || (Neck.North<- + Neck.South<-) || (R1 + C1))) || Volume.2-3
Notes:
All pickup coils are wired in-phase This configuration is hum-cancelling
Switch configuration: [Pickup Selector.Rhythm:Series/Parallel.ON1:Tone Switch.ON1]
Parallel/Series connectivity tree: ((Volume.1-2 + R2) + (C2 || R3)) || (Volume.1-2 + Neck.North<- + Neck.South<-) || Volume.2-3 Notes:
'Neck' is the only engaged pickup
Switch configuration: [Pickup Selector.Rhythm:Series/Parallel.ON1:Tone Switch.ON2]
Parallel/Series connectivity tree: (Volume.1-2 + Neck.North<- + Neck.South<-) || Volume.2-3 Notes:
'Volume' potentiometer acts as a volume control for 'Neck'
Switch configuration: [Pickup Selector.Rhythm:Series/Parallel.ON1:Tone Switch.ON3]
Parallel/Series connectivity tree: (Volume.1-2 + ((Neck.North<- + Neck.South<-) || (R1 + C1))) || Volume.2-3
Notes:
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON1:Tone Switch.ON1]
Parallel/Series connectivity tree: ((Volume.1-2 + R2) + (C2 || R3)) || (Volume.1-2 + Bridge.North<- + Bridge.South<-) || Volume.2-3
Notes:
'Bridge' is the only engaged pickup
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON1:Tone Switch.ON2]
Parallel/Series connectivity tree: (Volume.1-2 + Bridge.North<- + Bridge.South<-) || Volume.2-3
Notes:
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON1:Tone Switch.ON3]
Parallel/Series connectivity tree: (Volume.1-2 + ((Bridge.North<- + Bridge.South<-) || (R1 + C1))) || Volume.2-3
Notes:
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON2:Tone Switch.ON1, Pickup Selector.Middle:Series/Parallel.ON2:Tone Switch.ON1, Pickup Selector.Rhythm:Series/Parallel.ON2:Tone Switch.ON1]
Parallel/Series connectivity tree: ((Volume.1-2 + R2) + (C2 || R3)) || (Volume.1-2 + Bridge.North<- + Bridge.South<- + Neck.North<- + Neck.South<-) || Volume.2-3
Notes:
'Bridge' and 'Neck' pickups engaged, wired in series
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON2:Tone Switch.ON2, Pickup Selector.Middle:Series/Parallel.ON2:Tone Switch.ON2, Pickup Selector.Rhythm:Series/Parallel.ON2:Tone Switch.ON2]
Parallel/Series connectivity tree: (Volume.1-2 + Bridge.North<- + Bridge.South<- + Neck.North<- + Neck.South<-) || Volume.2-3
Notes:
Switch configuration: [Pickup Selector.Treble:Series/Parallel.ON2:Tone Switch.ON3, Pickup Selector.Middle:Series/Parallel.ON2:Tone Switch.ON3, Pickup Selector.Rhythm:Series/Parallel.ON2:Tone Switch.ON3]
Parallel/Series connectivity tree: (Volume.1-2 + ((Bridge.North<- + Bridge.South<- + Neck.North<- + Neck.South<-) || (R1 + C1))) || Volume.2-3
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
Notes:
