syddd
Post by syddd on Apr 22, 2023 22:09:28 GMT -5
Hello Everybody
Can someone steer me in the right direction here?
I have experimented with taming pickups with capacitors and resistors before, so I understand putting capacitors and resistors in parallel so that I am reducing the low end and letting the top end through to get a slight volume cut like below;
|---C1---------| Volume------| |---------Pickup------Ground |---R1---------|
However I am trying to conceptually understand what happens in the below scenario - is it going to be two stages of frequencies getting let through high pass filters? Or does this start getting too curly?
|---C1---------| | | Volume------|---R1---------|---------Pickup------Ground | | |---C2---R2----|
P.S. Yes I have tried lowering the pickup volume, it works to an extent but loses the top end response
bluemurder
Post by bluemurder on May 10, 2023 5:21:31 GMT -5
Both scenarios are very similar as they will both reduce low end, depending on the resistor/cap values. The overall volume is not really reduced.
