Post by mikeliterus on Jul 23, 2023 7:15:54 GMT -5
Can someone take a look at this and let me know if it will work? Thanks in advance. All pots are 500k , pickup covers are grounded via the star method where applicable, it's a 4 way tele series/parallel switch, with a middle pickup (fralin steel pole 43 hence the 500k pot), volume control (push-pull) that would allow you to add the middle pickup in series or parallel to any of the 4 pickup selections creating 12 possible combinations, also a stacked G&L PTB tone control and a kill switch. if this works , I believe the tone control will only work on the neck and bridge pickups is there a way to wire it so it would work on all three? I'm trying to do something i haven't seen before with the pickups and their layout being angled humbucker bridge, tele neck in the middle and a p90 neck angle like an old Mosrite in a custom Telecaster with a Floyd Rose. Thanks for taking time outta your day for input and advice. imgur.com/a/5KrfTRc
Post by newey on Aug 1, 2023 5:18:42 GMT -5
mikeliterus- Sorry no one has responded to you sooner, I've been away for a few days and I suspect others have as well, July and August are our slow months around here. In any event, I have not gone through your diagrams fully yet, but I do see at least one issue with the middle pickup's series/parallel switch. The middle pickup's "hot" lead is permanenetly connected to the output jack (via the middle Vol pot, while the middle pickup's ground lead goes to the push/pull. In one position of the push/pull, that lead is grounded, meaning the middle pickup will always be "on" with the push/pull in that position regardless of the 5-way switch position- not what you wanted. I'm also not seeing how the 5-way switch connects to the output. So, let me take a longer look, but I see a couple of issues at a minimum.
