dmalbans
Post by dmalbans on Sept 8, 2023 12:38:51 GMT -5
HSS 1vol, 1 tone, 5way switch, coil tap. I can't make sense of any of the wiring diagrams. Could anyone finish the diagram? Kind regards
Post by mikecg on Sept 9, 2023 8:13:15 GMT -5
HSS 1vol, 1 tone, 5way switch, coil tap. I can't make sense of any of the wiring diagrams. Could anyone finish the diagram? Kind regards Wow! You have some choice components - there! I can't see any wiring diagram to finish - but you could try this one - and I'm guessing you have a strat of some sort?
Post by newey on Sept 9, 2023 18:24:43 GMT -5
mikecg- Not sure that you've followed the wire colors set forth by dmalbans, he seems to be indicating green/red as the series junction ("seems" as he doesn't label the wires specifically). Your diagram is fine but for the assumptions as to the HB wire colors (and we don't know whether phasing with the SC pickups either, for that matter). dmalbans- It would be useful to know the type of pickups being used, and whether they are all from the same manufacturer, to resolve these issues before you start wiring.
