Post by stevewf on Oct 4, 2023 19:45:22 GMT -5
Hi Nutz2's. I bought one of Stewmac's "Offset Trem" kit guitars (stock photos on Stewmac site here). I intend to modify it while building it; like stainless steel frets, better trem, different pickups, different wiring and controls.
The biggest change I'm planning is to use three single coil pickups, kinda like a Strat, including a RWRP middle coil. Unlike a Strat, the middle coil would be moved right next to the bridge coil. So the pickups would look like a Humbucker and a Single coil. I'd been cooking the idea for a while, and then was emboldened by Squier's Contemporary Stratocaster Special. I was pleased to see that in addition to scooting the middle coil, they'd changed the function of the blade switch - there's a serial combo in there, and an all-coils one (not documented, but I bet the all-coils is (BxM)+N).
The controls I've settled on: a 5-way pickup selector, a master Vol, a master Tone and a Phase switch push-pull in one of the pots.
I'd like the switches to do this:
5-way:
Phase switch affects positions 3 & 4:
Here's a schematic of a solution that I think covers the above (Postimages)
There's an unused pole on the Superswitch.
I couldn't figure out a way to use 2-gang pots to offer separate Vol/Tone circuits for Position#3 (serial) without needing two poles of the 5-way. I'm choosing 500K needles instead of 250K mud.
There's a way to get either of the Bridge coils alone, using Position#2: Phase Dn=Inner, Phase Up=Outer.
I could invert the Phase switch (i.e. make it Up=In Phase) by swapping the two pairs of throws on s2. But I favored Down=In Phase.
To get In-phase hum cancelling, it's easier to find RWRP middle coils (harder to find one of the outer coils RWRP).
Coupled with an RWRP middle coil, this means that "normal" (In Phase) uses the inner coil in Positions#2, 3 & 4 in my schematic. (Again, to get the outer Bridge coil alone, it's Position#2/Up)
I wanted Position#1 to be Bridge Series. Fiddliness to get the Bridge Outer coil alone is a consequence.
I considered a series fader. There'd be a bit more body routing to add a 3rd control knob, which would be a but tightly clustered.
I considered moving the jack to the edge, in order to free up space in the control cavity. Sounds like a lot of Forstner. I have a cordless hand drill. Gulp.
These mods will require a new pickguard (getting rid of the 3-way toggle, instead using a 5-way blade near the lower horn) and some body routing (for the blade switch and its wire channel). But like I said, I've settled on these controls, with maybe-maybe-maybe also using the cavity where the 3-way used to live (upper horn).
Here's what I'm asking for:
5-way:
Pos# | Coils |
5 | Neck |
4 | Bridge (single) + Neck |
3 | Bridge (single) x Neck |
2 | Bridge (single) |
1 | Bridge (series HB) |
Down | In phase |
Up | Out of Phase |
- A vetting of the schematic, and proposals for improvement
- Any warnings about the proposed physical pickup layout. Two single coils next to each other; is it a bad idea?
- Thoughts on choice of pots (250K or 500K?).
- Ideas for using the existing rout where the 3-way toggle once lived.
- General sanity checks welcome. Anything look terribly wrong?
