underhill
Post by underhill on Oct 15, 2023 13:19:50 GMT -5
i am putting together a "utility" semi-hollow body guitar to do some comparisons between various picks. i have 2 harnesses for 250k and 500k pots/cap mounted on their own dedicated pickguards (i got some regulation thickness single ply pickguard stock and cut to the original pickguard and drilled them for just 3 screws to make changing over easy) to switch between hums and single coils/P90s. what i would like to do is come up with a quick connect jack of some sort and wire these harness for easy plug in for the for assessing the sonics on these pickups. i can just wire one end of the pickup plug it into the harness side. so, i found many sources for quality 28ga wire, but not finding exactly what i'm looking for male/female micro connectors. is anyone here with a link to a possible source on this? i realize that a non-soldered connection in the signal path would pose possible detriment to the closed loop of pickup to harness, and harness to input jack- but, this would be short term as i figure a week to 10 days going through the various tests.
so, if anyone here knows of a possible source on these i would greatly appreciate the info.
underhill
Post by underhill on Oct 15, 2023 13:32:55 GMT -5
disregard. my brother tipped me off to Digi-Key and they offered these- look like they would work fine- there's ample room in the electronics cavity of this guitar as long as the size of the shielding around the connector itself stay small.
