0etzi1977
Post by 0etzi1977 on Oct 17, 2023 10:23:21 GMT -5
Hi! I've recently purchased an HSS set: Neck-single Middle-single Bridge-4 wire humbucker
Now I have to wire it all and I was thinking about this config:
Global volume using Dual 250K(neck/middle)-500K(BridgeHumbucker) fender pot
Neck+Middle Tone using one 250K CTS Pot Log
Bridge Tone using 500K Pot Log Push/Push for Bridge Coil Split.
5 way Fender Blade switch.
Is it a clean wiring possible with that config or do I need Megaswitch (the one with two separate contacts wafer)? I'm a little bit confused about the correct wire routing... Does anyone know a wiring scheme for that config? I don't think it's so unusual.
My doubt is mainly about keeping the bridge and neck/middle controls separated, do I need to solder the input wires from the pickups directly on the volume lugs and adjust the wiring accordingly to it, or there is a way to mantain the "output" mixed pickups signal from the switch to the volume but... in this case how can I separate Bridge signal from Neck/Middle? I don't think it's possible, right?
Thanks in advance!
Post by newey on Oct 17, 2023 12:11:51 GMT -5
Correct, more or less. You would not need a Superswitch to do this, a regular 5-way switch would suffice. The bridge's Vol (one-half of the dual-gang pot) would get wired directly after the pickup, before the 5-way switch. The bridge tone is then wired off the bridge's vol pot in the standard fashion. The separate N/M tone (other half of the dual-gang) and N/M tone would be wired off of lugs 2 and 3 on the 5-way, where the Strat's tone controls are usually wired per a std. Fender Strat wiring- goes to V pot first, N/M tone is then wired off the N/M vol pot.
The downside of this scheme is that, in the 2nd position of the 5-way (B + M) you'll effectively have 4 pots in the circuit- both halves of the Vol, and both tone controls. On a regular Strat, the most you ever have is 3 pots at once, in position 4 (N + M). Having a 4th can dull the tone. Making one (or both) of the tone pots a"no-load" pt would alleviate that issue.
Post by reTrEaD on Oct 18, 2023 9:13:05 GMT -5
Is it a clean wiring possible with that config or do I need Megaswitch (the one with two separate contacts wafer)? I'm a little bit confused about the correct wire routing... Does anyone know a wiring scheme for that config? I don't think it's so unusual. My doubt is mainly about keeping the bridge and neck/middle controls separated, do I need to solder the input wires from the pickups directly on the volume lugs and adjust the wiring accordingly to it, or there is a way to mantain the "output" mixed pickups signal from the switch to the volume but... in this case how can I separate Bridge signal from Neck/Middle? I don't think it's possible, right? You would definitely want to use a 4P5T (either a superswitch or a Schaller Megaswitch M), else you'll face problems that can't be avoided. Also, using a separate push-pull to split the HB is clumsy. Having the HB split in the Bridge-only position sounds pretty awful and having the full HB in the Bridge + Middle position is not particularly useful. Better, I think, to have the #2 position (Bridge + Middle) autosplit the HB. The dual-gang volume pot is overkill. Adds complexity and not much bang for the buck. A bridge HB with a 250k volume pot sounds just fine. I'd use a regular 250k master volume and call it a day. With a 4P5T, one pole can be dedicated to selecting which one (and only one) tone pot is selected in each position of the selector switch.
0etzi1977
Post by 0etzi1977 on Oct 25, 2023 4:37:05 GMT -5
"Having the HB split in the Bridge-only position sounds pretty awful and having the full HB in the Bridge + Middle position is not particularly useful." Respect for your tastes, but I don't find the hb split bridge only awful and Bridge + Mid Position unuseful... for me just tasted good, What about this config? I've used a normal 5-pos switch
the small switch should add the Bridge pickup in neck position
