billbit
Post by billbit on Oct 24, 2023 20:42:45 GMT -5
Hello, I have been looking into building a partsmaster but really wanted to use p90s instead of standard JM pickups. I came across the Fishman Fluence Greg Koch p90s and they are currently my top choice to use. These pickups have 3 switchable voices. All wiring diagrams use pull pots to change voicings. I was wondering if you could wire an on/on/on switch to switch between the voices instead of the pots.
Post by sumgai on Oct 24, 2023 22:41:11 GMT -5
billbit , Hi, and to The NutzHouse! The short answer is Yes. You can use any kind of switch you wish, so long as it performs the functions you wish to achieve. Toggle, slide, rotary, blade, push-button, push-pull, push-push, they're all fair game. The only limit is how you want to operate said switch(es) to change something from A to B (or C, etc.) The long answer was just covered, I'm sure you'll agree. But if you have questions, or need help "translating" between switch types, we're here to help... just ask. HTH sumgai
billbit
Post by billbit on Oct 25, 2023 5:53:12 GMT -5
billbit , Hi, and to The NutzHouse! The short answer is Yes. You can use any kind of switch you wish, so long as it performs the functions you wish to achieve. Toggle, slide, rotary, blade, push-button, push-pull, push-push, they're all fair game. The only limit is how you want to operate said switch(es) to change something from A to B (or C, etc.) The long answer was just covered, I'm sure you'll agree. But if you have questions, or need help "translating" between switch types, we're here to help... just ask. HTH sumgai Thank you for the response, very good to know. Do you know how this could be done, because I haven’t been able to find any diagrams explaining how to do so.
Post by newey on Oct 25, 2023 21:03:23 GMT -5
It would be helpful for you to post the wire colors for these pickups and also one of the diagrams you saw using a push/pull switch. We could then adapt to the other switch type from there.
billbit
Post by billbit on Oct 26, 2023 6:14:22 GMT -5
